EAGLE User Support (English) Traces showing over holes
  • Replies 7 replies
  • Subscribers 180 subscribers
  • Views 1044 views
I reinstalled windows and eagle recently, and now Eagle does something it didn't use to do before.
The holes are now covered with traces, and I don't like it.
Anyone maybe familiar with this problem? Thanks in Advance image
PS: Sorry if I made some mistakes, English is not my mother tongue.
    Try to print the board onto paper, then the holes should be emty.
    Mogens
    0 Former Member over 10 years ago in reply to Former Member
    Heh I do not own a printer, I usually take pics to be printed in a local printing house, so that is not an option. But thanks anyway.
    On 7/02/2015 9:05 a.m., Miloš Glendža wrote:
    You did not say which version of Eagle you are now using.
    You did not say how you arrived at the image you posted .
    On v6.6 or v7.1 I don't see that issue when I print to a pdf
    HTH
    Warren
    0 Former Member over 10 years ago in reply to autodeskguest
    Sorry, didn't think it was relevant.
    The version is 6.6.0.
    I do this:
    1) set palette white; ra
    2) display none bottom pad via; ra
    3) File >> Export >> Image (600 dpi, Monochrome) >> Ok
  • guidoeagle
    0 guidoeagle over 10 years ago in reply to Former Member
    when I export a layout as an image I get the same behaviour as you described in your first post (Eagle 6.6.5 & 6.6.0). Exporting a layout as an image is not the best way for pcb production in my opinion. Use the CAM-processor to export your layout. I know the CAM processor is not able to create images as raster graphics (*.png) but you can create a vector graphics in postscript (*.ps) format. This is anyway much better. Your local print house should be able to handle this format. Use ghostscript (http://ghostscript.com/) and ghostview (http://pages.cs.wisc.edu/~ghost/gsview/index.htm) to show *.ps-files on your computer.
    Best regards
    Guido
    0 Former Member over 10 years ago in reply to guidoeagle
    Actually it is (was) a great and easy way of creating images for toner transfer technique. I guess I'll check those things out, oh well. Thanks!
    EDIT: Installed Eagle 7.1, same thing. This really sucks.
  • guidoeagle
    Thanks!
    it's not that complicated. Load your project and click on the
    CAM-Processor symbol in the tool bar of the board editor. In the
    CAM-Processor dialog click "File" => "Open" => "Job..." and load a cam
    job file (for example the one I've attached here). After that click on
    the "start job" button. After that you will find two postscript files in
    your project folder. The postscript file for the component side is named
    "*.cmp.ps", the postscript file for solder side is named "*.sol.ps".
    You can open these files with ghostview and convert them to raster
    graphic files ("File" => "Convert..."). But believe me, when you ever
    had worked with the vector graphics format you won't use the raster
    graphics format for your pcb layouts anymore.
    Best regards
    Guido
    P.S.: As I use a German eagle version the naming of the menu items and
    buttons might be slightly different as translated here.
    8103.att1.html.zip
    MyCamJob.cam.zip
