EAGLE User Support (English) ULP: how to open a library when ULP was started in a schematic??
  • Replies 11 replies
  • Subscribers 189 subscribers
  • Views 1635 views
  • ulp
Joop14
Joop14 over 11 years ago
Hello all,
I want to do something simple but somehow I can not find the right way or command.
I'm writing an ULP that is going to be started from a schematic.
In the ULP, I want to write code that opens a library so that I can access the properties of devices in a library.
How do I do this?
Kind Regards,
Joop
  • Joop14
    0 Joop14 over 11 years ago in reply to autodeskguest
    Still, I'm not able to open a library from within a schematic.
    Anyway, even if I could, I doubt if it will be of much use in my case.
    The c interpreter is too slow compared with compiled c code.
    To check a design with 500 devices against the library takes some seconds, you have to parse the xml files.
    I guess it would take a minute to do this with the c interpreter.
    Not taking into account the time Eagle needs to open and close every available library...
    I just looked at your problem quickly,
    but we have access to the entire database schematic from BRD console,
    I myself had the same kind of problems:
    this following code independently of the calling consol type (Schematic
    or board) execute PCBJob() function in BRD environement and SCHJob
    function in the schematique environement
    if (schematic) schematic (S) {
       SCHJob (S);
       project.board (B) PCBJob (B);
    else if (board) board (B) {
       project.schematic (S) SCHJob (S);
       PCBJob (B);
    http://www.element14.com/community/message/155203
  • Joop14
    Ok, the Eagle library checker is ready.
    If somebody else wants to try it, you can find it here: http://www.teuniz.net/eagle/eaglelibcheck/
    It runs on Linux but it's opensource, so if you feel like, you can modify it to make it work on Mac or Windows.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    "warrenbrayshaw"  skrev i nyhetsmeldingen: mc7u3h$fq3$1@cheetah.cadsoft.de
    1. Using two ULPs.
    Just a minor comment to that.
    Of course you can do it all with one single ULP. It causes a tidyer ulp
    folder. You simply pass some self interpreting arguments via argv,argc.
    (Note:argv[0] is the ulp name itself so we can use this to rerun ourselves
    even if the ULP gets renamed):
    if(argc==2 and argv[1]="SecretKeywordToStartStage2")
        //stage2
        exit(EXIT_SUCCESS);
    else
        //stage1
        sprintf(cmd,"dosomething;run %s SecretKeywordToStartStage2;",argv[0]);
        exit(cmd);
    Also its good to know how to  access board and schematics from the same ulp
    by:
    if (project.board) project.board(B)
    if (project.schematics) project.schematics(S)
  • Joop14
    Thanks Warren, your solution works.
    However, it wil not win a "beauty contest". It's more a kind of a hack.
    This is not your fault ofcourse. It's because of the limitations of Eagle & ULP.
    I'm not sure about the speed of opening and closing many different libaries (imagin you have a big design).
    Also, if an intermediate file is necessary to temporary store the properties of all the parts,
    why not just read directly from the xml files?
    So, I decided not to write an ULP. Instead, I'm going to write it in C.
    Thanks for the advice anyway.
    Joop
    On 21/02/2015 7:23 a.m., warrenbrayshaw wrote:
    Inspect the attached for the one ulp approach.
    All the best
    Warren
    schlbr.ulp.zip
    0 autodeskguest over 11 years ago in reply to Joop14
    On 20/02/2015 10:06 p.m., Joop14 wrote:
    I'll explain a bit more what I want to try to achieve.
    I want to write an ULP that performs a diff between the
    parts/devices/footprints in a schematic/board and the libraries.
    In order to do this, the ULP must be started in the console of the
    schematic/board because we need to have access to all the parts/devices
    used in the schematic.
    Also we need to have access to all properties and attributes of these
    parts/devices.
    Once we have this access (which is easy when you start the ULP in the
    console of the schematic or board), we need to have access to
    the libraries to compare the properties of the parts in the
    schematic/board with the parts in the libraries.
    I can have access to parts and properties of a library when I start tyhe
    ULP in the console of a library.
    So, the question is, how to open a library from within an ULP that has
    been started in a schematic or board.
    There are few ways to approach this:
    1. Using two ULPs.
      (a) Start the first in the schematic and gather all the required  info
        which you place in a file (my_file.txt)
      (b) Exit the first ulp which calls the second ulp.
       "Run 2nd_ULP my_file.txt"
    (c)Use my_file.txt to locate the library names/devices/symbols/packages
    of interest
    (d) compare the results
    2. Using 1 ULP
      This is the same as using two but all the code is in one ULP.
      (a) You sense when you are in the schematic and run that code portion.
      (b) Exit the first ulp which first opens the library editor and then
    calls itself in the library this time.
      (c) the library part of the code runs
    3.  Using 1 ULP - analyse the xml of the schematic which has all the
    device information and compare with the xml of the libraries
    I hope this gives you some ideas.
    Warren
    "Lorenz"  skrev i nyhetsmeldingen:
    c42eea92t3jch1gdbimgshco8gr7h950hm@4ax.com ...
    But I see no way the automaticaly start the ulp this way.
    You can write multiple commands in the exit string, separated by semicolon.
    You an do that when typing commands too.
    you would need to exit the ulp, open the library editor and start the
    ulp again (or an second ulp) there.
    exiting the ulp in the schematic and opening the library editor could
    be done with exit("edit libname;");
    Lorenz
  • Joop14
    I want to write an ULP that performs a diff between the parts/devices/footprints in a schematic/board and the libraries.
    In order to do this, the ULP must be started in the console of the schematic/board because we need to have access to all the parts/devices used in the schematic.
    Also we need to have access to all properties and attributes of these parts/devices.
    Once we have this access (which is easy when you start the ULP in the console of the schematic or board), we need to have access to
    the libraries to compare the properties of the parts in the schematic/board with the parts in the libraries.
    I can have access to parts and properties of a library when I start tyhe ULP in the console of a library.
    So, the question is, how to open a library from within an ULP that has been started in a schematic or board.
