EAGLE User Support (English) Using Eagle 7.2.0 Lite, how do I know if a new part  has plated through holes? 9as opposed to pads top and bottom).T
  • Subscribers 179 subscribers
  • Views 420 views
Hi
A new user.
Using Eagle 7.2.0 Lite, how do I know if a new part  has plated through holes? (as opposed to pads top and bottom).
    On 10/03/15 15:34, Tony Wright wrote:
    Hi
    A new user.
    That's a meaningless question.
    Parts don't have "plated-through" anything. Parts have symbols and
    packages. Packages have pads, which can be either SMD or through-hole.
    The latter have a drill size and a restring (and elongation), from which
    Eagle produces the necessary data for plating and drilling your PCB.
    No mention of plated through holes there.
    Now, what you do with your PCB data afterwards is up to you. If you send
    it to a professional PCB fab, they will probably through-plate all the
    holes unless you tell them otherwise.
    Plated through holes are controlled by the rules of the board house.
    Most commonly the board house will plate the hole if there is copper lands
    on both sides of the board at the position of the drill.
    If there is copper only on one side or neither side, the hole will be non
    plated. That drilling occurs later in the manufacturing process. It pays to
    learn the sequence of events in the manufacturer of a PCB then you can see
    what is controlled by the CAD and what is controlled by the manufacturing
    process.
    You normally have to ask for a non plated hole if there is copper both
    sides.
    The board house will tell you how they wish to be advised of these needs.
    HTH
    Warren
    0 autodeskguest over 11 years ago in reply to autodeskguest
    The eagle primitives 'via' and 'pad' are always ment to be plated. For non
    plated holes, there is the 'hole' primitive.
    For course if you drill your own vias and pads, you have to make sure they
    are connected at both top and bottom. If its a pad, it may be difficult to
    actually solder the pin on both sides, but there is no such thing as a
    bottom only pad in eagle. Maybe there should be since farnell/cadsoft does
    seem to target the low entry users..
    To keep those types of drills separated, I made my own CAM that creates
    separate drillfiles for nonplated (holes) and plated (vias/pads). For some
    reason eagle puts up a warning when I do that, but its very natural for me
    to separate them and manufacturing house never complained.
