EAGLE User Support (English) Noob at this... trying to generate Gerber and its too big
  • Replies 16 replies
  • Subscribers 181 subscribers
  • Views 3811 views
  • gerber
Ok so long story short, I fly RC aircraft one of them being micro size quadcopters, and I designed a circuit for one of them.  It looks good but when I try to export as a gerber using the CAM thing it makes the gerber files way too big... the size of the whole circuit is only about 25mm x 25mm or so but it makes the file huge (I use an online gerber viewer) webGerber
I have tried several "jobs" to no avail... getting very annoyed.  It makes the circuit correctly, but it makes the board way way too big.  I attached the brd file... if you can't help me do it myself, can someone at least do the gerber conversion for me? image
4brushintegrated.zip
    Former Member over 11 years ago +1
    Success! I ignored the preview stuff and uploaded it to a PCB site... and voila! Attachments:
    Ok... got the cutoff issue resolved, just had to redraw the dimensions.  But the drill file is still making it too big image
    well I guess I just keep solving my own problems a little at a time lol...
    I think it may have just been that viewer, because this one seems to show it:
    Wireless Data Acquisition and Data Logging Systems with Wireless Sensors - Paragon Robotics
    5008.Myownone.zip
    Success! image
  • e14candies
    0 e14candies over 11 years ago
    why do you have vias shorting (or what looks like shorting)to adjacent
    traces?
    There is plenty of room available for you to work with--why not use it?
    0 autodeskguest over 11 years ago in reply to Former Member
    lol...
    show it:
    - Paragon Robotics
    (http://paragonrobotics.com/halo-s/?jumpToTab=gerberViewer)
    There are some aspects of the Gerber and Excellon (drill) file formats
    which are not as well defined as one might hope. For example,
    coordinates are quoted in multiples of the resolution, but the
    resolution has to be guessed at. Eagle uses a fine resolution (this
    actually changed between V6 and V7, I think) which some viewers don't
    cope with. Some, rather obscurely, cope with it in the Gerbers but not
    in the Excellon, resulting in the drills appearing nowhere near where
    they should be.
    It's possible the TXT file you removed confused the first viewer in that
    way, but the Paragon one works better.
    Personally, I never use web-based tools if I can install a better one.
    There are several free ones available. I use gerbv.
  • emmamai123
    0 emmamai123 over 8 years ago in reply to Former Member
    Glad to know you are successful .
