EAGLE User Support (English) Design of PCBs
  • Subscribers 179 subscribers
  • Views 509 views
  • frontpage
Design of PCBs
How to create exposed pads in Eagle packages??
    0 shabaz over 10 years ago
    Hi Ashna,
    Put a polygon or rectangle on the tStop/bStop layer over the specific area on the top/bottom copper respectively. You don't usually need to do that, because pads already have that done for you. EAGLE is flexible and allows you to manually do it for certain use-cases.
    Am 20.04.2015 um 13:10 schrieb Ashna Gupta:
    Examples in   "texas.lbr"
    DRC-S-PVSON-N10.PAC
    DRK_S-PDSO-N10.PAC
    HTQFP-64-PAP.PAC
    HTSSOP8DGN.PAC
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
    0 Former Member over 10 years ago in reply to shabaz
    But then how do I name the polygon as the pin on the symbol of the device? There is no Name option which means that it won't be shown as connected. How do I fix that?
    0 Former Member over 10 years ago in reply to Former Member
    Am 20.04.2015 um 13:39 schrieb Ashna Gupta:
    Please read ...\doc\manual_en.pdf
    Chapter  8.14 Arbitrary Pad Shapes
    Alfred Zaffran
    0 shabaz over 10 years ago in reply to Former Member
    Hi Ashna,
    Your question was "How to create exposed pads in Eagle packages??"
    and  the answer is (as mentioned) "You don't usually need to do that, because pads [i.e. through-hole pads, and smd] already have that done for you".
    Your further comment is a different question, but there is no context/explanation of what you're really trying to do, and this thread could end up very long if I just try to guess, so it will be better if you explain the scenario/use-case and then the requirement in detail.
