EAGLE User Support (English) PCB component name (hierarchical design)
  • Replies 7 replies
  • Subscribers 180 subscribers
  • Views 1273 views
  • eagle
  • pcb
apica
apica over 10 years ago
I'm making a design with Eagle 7.2.0 and using the hierarchy feature. In each hierarchic bloc, the name of each component starts from 1 (U1, U2, ...). The problem is on the PCB design, because the hierarchic bloc name is added in each component.
For example, the bloc "SUPPLY" have the components C2 and R3. In the PCB view, the name of the components are the following:
Is it possible to show only the component identifier (C2 or R3) without showing the hierarchic bloc name (SUPPLY) on the PCB?
Thank you!
    autodeskguest over 10 years ago in reply to Former Member +1
    On 22/12/15 16:32, sunny duan wrote: Professional PCB manufacturer here Really? Because as far as your presence here would indicate, you're actually a highly unprofessional SPAMMER. Go away.
  • clem57
    clem57 over 9 years ago in reply to autodeskguest +1
    Reported to moderator ty
  • clem57
    0 clem57 over 10 years ago
    No, this is not how it works. What you really do is compose a small schematic and expose the various leads. Please watch this demo to see how it works: https://www.youtube.com/watch?v=X7FkzqIGsqU
    Clem
  • apica
    0 apica over 10 years ago in reply to clem57
    Thank you for replying.
    I already saw this tutorial, and I made the supply module with the input/output leads.
    And inside the module...
    I'm just asking about the naming of the components in the board editor.
    Thank you
  • clem57
    0 clem57 over 10 years ago in reply to apica
    In the tutorial they said the names inside were unique to outside. This implies they need to use a qualified name outside, hence the Supply:R3 for instance.
    Clem
  • apica
    Thank you, I only wanted to know if there is a way to change this.
    [deleted]
    0 autodeskguest over 10 years ago in reply to Former Member
  • clem57
    0 clem57 over 9 years ago in reply to autodeskguest
