EAGLE User Support (English) Eagle 7.2 Win install directory -- why non-standard?
  • Replies 24 replies
  • Subscribers 191 subscribers
  • Views 5519 views
  • eagle
  • installation
gwideman
gwideman over 11 years ago
Hi all,
I went to install Eagle 7.2, and immediately got stuck when it offers a default install directory of C:\EAGLE-7.2.0.  OK, why?
In general I don't want apps installing themselves in random top-level locations; why can't Eagle just install in one of the standard locations?
So, I could just edit the suggested location, but to which standard location? Is Eagle a 32-bit app or a 64-bit app? And maybe there's some crucial reason why it can't be installed to one of those?
Eventually I found online a file "v7.2_en.pdf" EAGLE Update Information, which contains the enigmatic remark "On Windows the default installation path in the setup dialog has been changed from the Windows program folder to C:\EAGLE-<version> (<version> being the full EAGLE version string)."
No explanation of why this change, and how crucial it is to abide by it. Maybe it's just a mistake?
FWIW, I changed the path to C:\Program Files (x86)\EAGLE-7.2.0. Even doing that was a hassle because the Browse window won't allow you to browse then enter the name of the new installation directory. But it is possible to back out of that window and enter the desired path by hand.
After installation, I checked the eagle.exe executable, and it is a 32-bit app, so I guessed correctly on the location.
Still don't know if this will cause problems downstream though.
Any further info on this?
-- Graham
  • gpsmikey
    0 gpsmikey over 11 years ago in reply to clem57
    Yeah, I was trying to figure out just where we were going with that (although my son IS an Eagle Scout ! )
    mikey
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Eagle software is not a eagle scout form. LOL
    If anyone needs to fill out a eagle application, I found a blank form here: EAGLE SCOUT RANK APPLICATION Fill Online, Printable, Fillable, Blank - PDFfiller
  • gpsmikey
    0 gpsmikey over 11 years ago in reply to autodeskguest
    Very good information.  I guess from my knothole (and many others), the
    biggest problem with the "virtualization" scheme that M$ implemented is the
    fact that they don't bother to tell you they didn't put your files where
    you thought you put them.  Give me a pop-up indicating the specified
    location is NOT legal for user files and where they are being stored.  Most
    people that run into this don't have a clue what happened.  And it can be
    pretty insidious at times - different software, the company sent me a new
    key file by email.  I grabbed the keyfile (license) and dragged it onto the
    install directory for their software (where it belonged).  Didn't work -
    seems if you drag from the email, it does not have the rights to be put in
    the install directory (under /Program Files(x86) ) so it puts it in the
    virtual store WITHOUT telling you.  If you drag it to the desktop first
    THEN to the install directory, that works (at least as an admin).  I
    understand the attempt to protect the install directories, but TELL the
    user you did not do what they asked, not simply do something else then say
    "OK".
    mikey
    0 autodeskguest over 11 years ago in reply to gwideman
    Hi Graham,
    I actually have an element-14 account, the problem is that I access the
    newsgroups through Thunderbird and NNTP. Element14's interface to this
    server is less than stellar and this is just one of it's issues.
    I don't want to go through the web portal so I just deal with the
    Cadsoft guest situation by writing my name in every post I write. So if
    you see my name you know its me.
    Best Regards,
    Jorge Garcia
    On 01.05.2015 11:55, Graham Wideman wrote:
    By way of refining my calibration on this topic, I'd be curious what
    tools those are.
    Both my FPGA tools from Altera (Quartus) and Xilinx (Vivado/ISE) uses
    this method. Most likely unlrelated, but common to them both is that
    they contain abundance of small files (Quartus:113k5, Vivado:61k5).
    It appears to me like most cross platform tools prefer their own folder
    top level. But Im working on single user computer and it works fine,
    wich is probably why they dont even try to change it.
    But in the end, Id also like Eagle's default user files to be protected
    and default paths set outside program root folder.
  • gwideman
    0 gwideman over 11 years ago in reply to autodeskguest
    To Guest who replied:
    > There are two versions of the Windriver / Diab C compiler for PowerPC,
    > Gimpel PCLint, the Lauterbach in-circuit debugger tools, and one other
    > that escapes me right now. Of those, I think the compiler can (with some
    > effort) be made to work in Program Files, I'm not sure on the others.
    > These are all rather elderly versions, though, so it's possible the
    > recent ones are more conventional.
    This is similar to my experience. As you say, in general more recent software has been following the installation plan that has been increasingly conventional (on Windows) starting around Win 2000.
    > I guess the difference is that [...]
    I agree that these kinds of tools come with a number of moving parts, and accumulate more as you use them. There's always a tension between the desire to keep all parts pertaining to a particular tool together in the directory structure, versus distributing those parts according to categories of "applies to all users" vs "applies to one person", and to the categories of security that can be applied. Those three priorities are often not apparent nor well understood by users, and sometimes not be developers either.
    > On Windows 9x this was less clear, so top level install was common.
    Hopefully decisions are no longer being made on the basis of supporting Win 9x!  :-)
  • gwideman
    Hi CadSoft Jorge
    Sorry I mistook one Guest for another. Jorge, haven't you been around long enough to earn your own account? :-).
    On 01/05/15 10:55, Graham Wideman wrote:
    At least four of the commercial tools I use at work install this way
    tools those are. I, too, have numerous software development tools,
    including embedded and desktop IDEs and build systems, and I believe
    virtually all are capable of installing in Program Files, though I don't
    dispute that there are some tools that can't.
    I haven't listed the half-dozen automotive / motorsport specific tools
    that also default to top-level installation, nor the SDKs for embedded
    OS's, because they're too specialist to count as "commercial", even
    though they are sold for non-trivial amounts of money.
    I guess the difference is that these are all tools which consist of
    quite a lot more than just some executables. Compilers come with a bunch
    of standard headers and libraries, debuggers have configuration scripts
    and flash programming algorithms. Also, these are files that the tool's
    user needs to know about, and probably inspect, possibly even modify. On
    Unix they would need to install into a number of different defined
    locations (/usr/bin, /usr/share/, /etc/) or to a defined "non-core"
    place like /opt. On Windows 9x this was less clear, so top level install
    was common.
    Just to clarify, the last comment wasn't by me, it was Rob but
    element-14 shows all of our posts as Cadsoft Guest which isn't very helpful.
    If there's anything I can do for you, let me know.
    Best Regards,
    Jorge Garcia
