    • Avnet Boards Community
EAGLE User Support (English) Eagle 7.2 Win install directory -- why non-standard?
  • Replies 24 replies
  • Subscribers 177 subscribers
  • Views 3766 views
  • eagle
  • installation
gwideman
gwideman over 10 years ago
Hi all,
I went to install Eagle 7.2, and immediately got stuck when it offers a default install directory of C:\EAGLE-7.2.0.  OK, why?
In general I don't want apps installing themselves in random top-level locations; why can't Eagle just install in one of the standard locations?
So, I could just edit the suggested location, but to which standard location? Is Eagle a 32-bit app or a 64-bit app? And maybe there's some crucial reason why it can't be installed to one of those?
Eventually I found online a file "v7.2_en.pdf" EAGLE Update Information, which contains the enigmatic remark "On Windows the default installation path in the setup dialog has been changed from the Windows program folder to C:\EAGLE-<version> (<version> being the full EAGLE version string)."
No explanation of why this change, and how crucial it is to abide by it. Maybe it's just a mistake?
FWIW, I changed the path to C:\Program Files (x86)\EAGLE-7.2.0. Even doing that was a hassle because the Browse window won't allow you to browse then enter the name of the new installation directory. But it is possible to back out of that window and enter the desired path by hand.
After installation, I checked the eagle.exe executable, and it is a 32-bit app, so I guessed correctly on the location.
Still don't know if this will cause problems downstream though.
Any further info on this?
-- Graham
  • gwideman
    gwideman over 10 years ago in reply to autodeskguest +1
    To Guest who replied: > There are two versions of the Windriver / Diab C compiler for PowerPC, > Gimpel PCLint, the Lauterbach in-circuit debugger tools, and one other > that escapes me right now. Of those…
  • gpsmikey
    0 gpsmikey over 10 years ago in reply to autodeskguest
    Very good information.  I guess from my knothole (and many others), the
    biggest problem with the "virtualization" scheme that M$ implemented is the
    fact that they don't bother to tell you they didn't put your files where
    you thought you put them.  Give me a pop-up indicating the specified
    location is NOT legal for user files and where they are being stored.  Most
    people that run into this don't have a clue what happened.  And it can be
    pretty insidious at times - different software, the company sent me a new
    key file by email.  I grabbed the keyfile (license) and dragged it onto the
    install directory for their software (where it belonged).  Didn't work -
    seems if you drag from the email, it does not have the rights to be put in
    the install directory (under /Program Files(x86) ) so it puts it in the
    virtual store WITHOUT telling you.  If you drag it to the desktop first
    THEN to the install directory, that works (at least as an admin).  I
    understand the attempt to protect the install directories, but TELL the
    user you did not do what they asked, not simply do something else then say
    "OK".
    mikey
    If anyone needs to fill out a eagle application, I found a blank form here: EAGLE SCOUT RANK APPLICATION Fill Online, Printable, Fillable, Blank - PDFfiller
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    Eagle software is not a eagle scout form. LOL
  • gpsmikey
    0 gpsmikey over 10 years ago in reply to clem57
    Yeah, I was trying to figure out just where we were going with that (although my son IS an Eagle Scout ! )
    mikey
