EAGLE User Support (English) Variants and cream layer
  • Subscribers 179 subscribers
  • Views 360 views
  • variants
  • cream
p.wagner
p.wagner over 10 years ago
I am using population variants (Version 6.6.0).  One thing I find annoying is that for an unpopulated element no cream layer will be created.  Every change in the population therefore means that my manufacturer does not only get new mounting data (easy), but also a new cream stencil has to be produced (costly).
Is there a way to get cream layer 'entries' also for unpopulated parts?
Kind regards,
Paul
  • dukepro
    dukepro over 10 years ago +1
    On 05/13/2015 08:12 AM, Paul Wagner wrote: I am using population variants (Version 6.6.0). One thing I find annoying is that for an unpopulated element no cream layer will be created. Every change in the…
    Am 13.05.2015 um 14:12 schrieb Paul Wagner:
    Switch to variant save the board and start CAM-Processor to generate
    the mask of this variant.
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
  • dukepro
    0 dukepro over 10 years ago
    Paul,
    I understand the reasoning behind what Eagle is doing.  I had a case
    where I had two different packages of an IC that overlaid each other
    with the idea that if one package was not available, the board could
    accommodate one that was.  Thus, when populating the board, one would
    not want solder paste on the pads of the package that was not being
    installed since it could leave solder pasted underneath the package that
    /was/ being installed.
    As a work around, one should consider generating the board fabrication
    files with no variant selected, then, select an appropriate variant to
    build the BOM.
    HTH,
        - Chuck
    5287.att1.html.zip
  • p.wagner
    0 p.wagner over 10 years ago in reply to dukepro
    Hi Chuck,
    good point, I just wish I could decide whether to generate a cream layer footprint (for an unpopulated part) or not.
    Nevertheless, the work around works nicely, thanks.
    Paul
