EAGLE User Support (English) Can this library part be made?
  • Replies 7 replies
  • Subscribers 180 subscribers
  • Views 1097 views
  • eagle
  • components
  • library
layout4me
layout4me over 10 years ago
I need a library part of a LED from LED Engin part LZ4-00MA00
http://www.ledengin.com/products/emitters#LZ4
There is a dxf file available on the website.
When  I use the import-dxf.ulp  I can't get polygons... only wires.
Do I have to switch to another PCB layout program that has the ability to make any library part I wish to use?
Any help would be helpfull.
imageLZ4-0XXX-0707-P3_10W-Emitter(Customer)_RevC2.pdf
  • clem57
    0 clem57 over 10 years ago
    You can make what ever you want. See How to make a custom library part in Eagle CAD tool
  • layout4me
    0 layout4me over 10 years ago in reply to clem57
    Did you look at the land patterns that are in the attached pdf?
    I don't need round or rectangular pads....  that is easy
    Hoping for a better answer...
  • clem57
    0 clem57 over 10 years ago in reply to layout4me
    Sorry did not know of attached because my in box never shows. But did you use the ULP dxfimport? If so, there are limitations of supported types especially splines. Please read Import DXF file in Eagle Pro 6.2.0. I know it is old, but I have not seen new features since then.shabaz mentioned using inkscape (freeware) because it is good at reading DXF and can convert to HPGL format.
    Clem
    Yes it can be made.. Use a small smd pad and a polygon to make the
    shape. It will be a bit tricky but very possible.
    If you got the wires, you could try writing an ulp to convert wires to
    polygons, it shouldnt be that hard.
    0 autodeskguest over 10 years ago in reply to autodeskguest
    The hard bit is writing the ulp to adjust for the width of the wire you
    will use for the polygon. The dxf import will give a zero width wire at
    the outline of the custom pad so unless you bring it in half the width
    of the polygon wire width, the polygon will be oversize which matters as
    the scale of components reduce.
    Warren
    0 Former Member over 10 years ago in reply to autodeskguest
    Am 27.05.2015 um 08:14 schrieb warrenbrayshaw:
    Warren
    You can use led.lbr -> package LZ4-40U600.PAC from device LZ4-40U600.DEV
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
  • layout4me
    0 layout4me over 10 years ago in reply to Former Member
    Danke für deine Antwort. Dass hilft mir weiter.
    Grüßen,
    Peter
