EAGLE User Support (English) separating polygon fills
  • Subscribers 179 subscribers
  • Views 543 views
  • polygon
Hello, I want to start using poygon fills for traces on power planes, such as the piccie below.
I have named the above Polygon fill VCC.  The trouble is I have a ground fill (named GND) on the same plane and when I hit Ratsnest (which processes polygons) the ground fill does not separate from the VCC polygon:
Here are my polygon settings:
I tried mucking around with isolate of the GND fill polygon but it didn't help.
Can you please suggest how I can get the desired separation?
DougM
    polygon:
    didn't help.
    DougM
    http://www.element14.com/community/message/150969
    See help rank.
    Paul
    0 Former Member over 10 years ago in reply to autodeskguest
    That fixed it, Thank you Paul.
