EAGLE User Support (English) Need license to move to 64 bit Linux.
  • Replies 10 replies
  • Subscribers 180 subscribers
  • Views 819 views
I got a new computer.  My old license file is for a 32 bit, and apparently not valid for the 64 bit version.
What can I do?
    What can I do?
    http://www.element14.com/community/message/152382
    Hi David,
    I hope you're doing well. Licenses are not dependent on the system
    architecture, what errors are you seeing?
    Only two things can ever be wrong when licensing EAGLE. Either your
    installation code or your key file are incorrect. With a little more
    info I think I can get you up and running.
    hth,
    Jorge Garcia
    0 autodeskguest over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Fri, 12 June 2015 11:59
    What can I do?
    Hi David,
    hth,
    Jorge Garcia
    That's over-simplifying it Jorge.  The whole mess with version 7.0 (and
    only 7.0) could be what he is referring to.  He may have setup the license
    server on a 32-bit machine and now that same install won't work on 64-bit.
    Just speculating but the release of the v7.0 license makes this
    conversation more complicated.
    James.
    Order your EAGLE license right now from Stratford Digital at
    http://www.eaglecentral.ca
    0 Former Member over 10 years ago in reply to autodeskguest
    The error is:
    Your license is not valid for this version of EAGLE!
    Please contact CadSoft for an upgrade.
    I have 7.2 on by 32-bit machine and I'm trying to install 7.3 on the 64-bit
    machine.
    David Smead
    CadSoft Guest http://www.element14.com/community/people/cadsoftnntp
    created the discussion
    "Need license to move to 64 bit Linu
    x."
    To view the discussion, visit:
    http://www.element14.com/community/message/152499/l/re-need-license-to-move-to-64-bit-linu-x#152499
    James.
    That's a valid point, James. Nice to hear from you, hadn't seen you in
    the forums in a while. Let's see what the user comes up with.
    Best Regards,
    Jorge Garcia
    The error is:
    machine.
    0 autodeskguest over 10 years ago in reply to Former Member
    64-bit
    machine.
    Hi David,
    That would mean that you are likely using an older version of your key
    file. Please e-mail me support@cadsoftusa.com with your serial number
    and I'll send you a new packing list so that you can download your most
    recent key file and installation code.
    hth,
    Jorge Garcia
    The new packing list contents did not allow me to install the 64 bit version.  I get the same error.
    I'm trying to install in /usr/local/bin/eagle as root.
    Are there files laying around I need to purge.  I'm getting impatient.
    Hi David,
    I check and you have a V7 license make sure that you are using the last
    packing list I sent you to download your latest key file and
    installation code. The name of the key file doesn't change but the
    internals do, so make sure you are using the correct one.
    The error you mention would seem to indicate that you don't have a V7
    license, but that's not the case.
    hth,
    Jorge Garcia
    Here are the top two lines of the key file:
    CadSoft License Registration File
    Copyright (c) 2015 CadSoft
    The activation code is the same as the earlier version.
    I don't think I'm doing anything out of the ordinary, installing in the same directory as my 32-bit machine.
    I need this to work!!!!!!!  NOW.
    http://www.element14.com/community/message/153243
    Hi David,
    OK, let's get to bottom of this. Here's the office number call me and
    we'll get this done in one phone call. Something is not lining up and I
    think over the phone we can figure this out.
    954-237-0932.
    If you would prefer that I call you then e-mail me your number to
    support@cadsoftusa.com.
    Best Regards,
    Jorge Garcia
