EAGLE User Support (English) Default Net width
  • Views 1713 views
Default Net width
michaelbähr
michaelbähr over 10 years ago
Hello!
Somehow my Eagle draws Netwires with a width of 0. This is super thin, too thin. As far I can remember it should be 0.006.
How can I change it back to 0.006 instead of 0?
"Change width 0.006" in eagle.scr only sets the width for Wire not for Net.
I tryed some other options in eaglerc.usr like Sch.NetWireWidth="0.006" without success.
Does anyone have an idea?
Thank you.
Michael
  • michaelbähr
    michaelbähr over 10 years ago in reply to autodeskguest
    Set the default net wire width with:
    SET NET_WIRE_WIDTH 0.006in;
    Perfect. It is working. Thank you!!!
    Am 30.06.2016 um 10:16 schrieb Michael Bähr:
    Hello!
    Thank you.
    Michael
    Richard Hammerl
    autodeskguest over 10 years ago in reply to michaelbähr
    On 30.06.2016 11:10, Michael Bähr wrote:
    Hi Morten,
    thanks for your quick answer.
    You say:
    After selecting the net tool, you pick the width before you draw.
    Where can I do this in 7.6.0? Withhout rightklicking the existing Netwires?
    https://www.element14.com/community/message/200534
    A wire is a net that that is stand alone. The only difference between
    wire and net is when using the net drawing tool, it will attach to an
    airwire. A wire will just create its own netname and if you end it on
    top of a different one, there will be an overlap issue. You can rename
    the new wires to an existing netname and it will become part of that net.
    You can also start drawing a wire EXACTLY from a net (pad or
    net/wire-end), and the wire will become part of that net.
  • michaelbähr
    Hi Morten,
    You say:
    autodeskguest over 10 years ago in reply to autodeskguest
    On 30.06.2016 10:35, Morten Leikvoll wrote:
    On 30.06.2016 10:16, Michael Bähr wrote:
    Hello!
    Net.
    Thank you.
    Michael
    After selecting the net tool, you pick the width before you draw. Some
    nets belonging to classes may change width as you start drawing, but I
    think this is not the case for you.
    If you want to change existing drawn stuff, use "group" and "change width"
    I should add, use projects. Don't just open the .sch or the .brd by
    double clicking. If you start by creating a project, then always use
    load project upon opening, the used widths (and other parameters) will
    stay with the project. Yes, you can move your existing sch and brd to a
    new project.
    Hello!
    Thank you.
    Michael
