EAGLE User Support (English) Unable to change pad signal name connected to polygon
  • Subscribers 180 subscribers
  • Views 901 views
I am designing surface mount proto-boards. (I will upload my library once
done.) I am working ONLY in Board for this project. In my package library,
I created parts with SMD pads and through-hole pads.
I used "Signal" to name and connect some pads GND. I also have a polygon
on the solder side named GND.
I am unable to rename any of the pads that connect to GND. If I unroute
the polygon, no air-wires appear to the pads. If I use "Name" and click on
a pad, I select the nearest routed signal, not the pad. If I add a signal
from one of the pads to another net (such as VCC) I am asked to select a
name for the "combined" net. Even if I delete the polygon, I get the same
results.
In the attached file, please note the 4 holes on the top and bottom edge
of the board as examples.
Jeff Rockel
WI, USA
    results.
    Jeff Rockel
    WI, USA
    A layout without schematic will not generate a netlist, ergo no
    airwires. If you plan to upload your library later on, I think most
    users wouldn't find it very helpful if it is packages "only".
    Since packages are the most difficult thing to design, the symbols are
    most easy. Just a few lines and pins, or take symbols from a different
    library.
    So why don't you "paint" a symbol to your package and make it a device.
    With a device you can draw a schematic and most of the problems are solved.
    Gruß / regards
    Joern
    Joern,
    Vielen dank. Yes I can do as you suggest. I have airwires for signals
    connected to non-polygon net names. My issue appears to be an eagle
    limitation when working in Board only.
    I chose to work in Board only because the proto-board is intended to be
    generic. My design is based on a board I used many years ago. It had no
    through holes for connectors and was simple to make without any plating
    process. The solid ground plane on the bottom is the key to good, working
    prototypes.
    I will take another pass and paint some symbols.
    Wieder einmal, vielen dank.
    Jeff Rockel
    WI, USA
  • kcadsoft
    kcadsoft over 16 years ago
    results.
    What exactly do I have to do in that example to see the problem?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Klaus,
    SHOW GND;
    Then try and rename a drilled pad that is highlighted.
    If you are able to rename the drilled pad (which is part of a package) then my experience was a fluke.
    Thanks for the effort.
    Jeff Rockel
    WI, USA
  • kcadsoft
    On 07/30/09 22:26, Jeff rockel wrote:
    Klaus,
    SHOW GND; Then try and rename a drilled pad that is highlighted.
    The problem you're having is that the GND polygon prevents airwires
    from being generated between the GND pads. That's because these pads
    are already connected by the (calculated) polygon.
    Normally you would rename the net that the respective pin is connected
    to in the schematic, and the associated pad would be automatically
    removed from the GND signal.
    What you can do if you have only a board is to temporarily rename
    the GND polygon to, say, GND1, and then do RATSNEST. Now you get
    actual airwires attached to the GND pads. Delete whatever airwires
    are necessary to isolate the pad in question from the rest of GND,
    and then rename the polygon back to GND.
    Klaus Schmidinger
    Klaus,
    Many thanks to you and the others who contribute to this forum. I read all the posts to learn "fixes" before I encounter the "problem".
    Eagle has so much embedded power, yet is so simple on the surface. The underlying design is so elegant as compared to the Orcads and Altiums of the CAD world.
    Your support (and now my support, as well) will encourage more use and the continued success of Eagle and Cadsoft.
    Vielen dank!
    Jeff
    Jeff Rockel
    WI, USA
