EAGLE User Support (English) Add command - drop button and tree
  • Subscribers 179 subscribers
  • Views 736 views
I pressed the ADD icon and searched for a DIL package. Obviously lots of
libraries got expanded in the library tree view.
1) How do you shrink the tree again back to normal short of pressing a
thousand image buttons on all the libraries tha tgot opened?
Also
2)On some package in the middle of a library I pressed the "DROP" button.
What did that do? Did I delete something from the library that was
selected? I didn't see the part "dropped" into my board layout which s what
I thought it might do. SOmething changed in the tree view when I did it.
Sage
    dsage wrote on Fri, 25 September 2009 11:49
    Hi Dave,
    The libraries in the Add dialog are controlled with the "use" command.
    See "help use" for more info, note you can use wildcards.
    button. What did that do? Did I delete something from the library that was
    The "drop" button removes the selected library from the currently used
    libraries.  So it is a graphical interface to the use command.  But if you
    have a lot to do you're better to use the command line:
    use -*;
    use abc*;
    The above will remove all libraries from use and add back only those that
    start with "abc".  So the libraries abc1.lbr and abc3.lbr would be added,
    but not abz.lbr.
    I'd highly suggest copying any component you use to your own library
    (under revision control) and then you only add parts out of your library.
    And keep that library outside of the install directory.
    Now you use the command "use -*;use mylib" and then the add dialog will
    only have your library and you don't have to wait  the 10-20 seconds for
    all the libraries that come with CadSoft to load into the add dialog every
    time you add a part.
    Of course, if you want the libraries back to help find something then it's
    easy, simply type "use *" into the command line and every library in your
    library path will be added to the add dialog.  Which reminds me, you need
    to have the directory with mylib.lbr added to the library path in Control
    Panel.
    Hope that all helps...
    Cheers,
    James.
    email:  james@eaglecentral.ca
    web: http://www.eaglecentral.ca
    Specialising in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Which reminds me, you need to have the directory with mylib.lbr added to
    the library path in Control Panel.
    This prompts me to add: be sure to save your custom library someplace that
    it will be backed up. Same with CAM, SCR and ULP files. I was fine with my
    custom library, but forgot for the other files I modified and lost work
    because it was in Program Files.
    Jeff Rockel
    WI, USA
    I have mistakenly "dropped" a library part about a thousand times....:-)
    Thanks for your reply(s). I was aware of the USE command and have already
    made a library of my own.
    I was working on the tutorial in the book so I had all the libraries in
    use just for ease of looking around.
    So the one question still remains. How do you shrink the tree back down
    once it's been blown open by the search function.
    On a similar track. It seems once I searched for something I have been
    unable to get other libraries to show again i.e get back to the view of all
    the libraries. Seems like only the library where the item was found is
    visible in the tree.
      I have gone back and issued the USE command again but this seems a bit
    excessive to do every time you search for something.
    Sage
    Former Member over 16 years ago
    Delete the item you searched for & then enter, all lbr will show again
    r
    autodeskguest over 16 years ago in reply to Former Member
    Hmmm. I thought I tried that but your are correct  - clear the search
    field and press  and the orignal list of libraries returns.
    Not sure what I was doing.
    Sage
