EAGLE User Support (English) Eagle ULP change text
  • Subscribers 186 subscribers
  • Views 2711 views
  • eagle
  • ulp
msr.andi
msr.andi over 4 years ago
I'm not sure if this is the right place for Autodesk-Eagle ULP but....
I want to change the text of a TEXT field in BOARD.
But I'm sorry, I do not find how to do that.
I have to build a cmd string,which will be executed at exit(cmd) ???
How do I determine which text field should be changed with this cmd ( or on commandline in BOARD)?
I can loop through all text field - no problem. I can read the values - no problem.
but how to change a specific text field?
Can anybody help me please?
  • msr.andi
    0 msr.andi over 4 years ago in reply to shabaz
    Thank you. That's an idea. But I need to copy the whole board to an other layout for production.
    I didn't know and didn't figure out on first hand how to address a text field.
            string FileAndExt = filesetext(filename(B.name),"");
            B.texts(T) {
                    if (T.value == FileAndExt ) {
                        text_change_counter++;
                        string tmpString = "";
                        sprintf(tmpString,"CHANGE TEXT %s (%f %f);\n",
                            FileAndExt, u2mil(T.x), u2mil(T.y));
                        cmd += tmpString;
    I go through the textfields on BOARD. When I find the proper field (BOARD file name ">DRAWING_NAME"), I get the x/y coordinates.
    These coordinates are now to address the textfield for e.g. CHANGE.
    0 shabaz over 4 years ago
    I don't know the answer to your specific question, but I know how I'd work around it to achieve a similar result.
    The EAGLE board files are plain-text, no checksum or anything, so you could write code/script in any favorite language, to search-and-replace the relevant text.
  • cstanton
    0 cstanton over 4 years ago
    Moved to Eagle forums
