EAGLE User Support (English) which capacitors are surface-mount?
  • Subscribers 177 subscribers
  • Views 266 views
jgowen
jgowen over 16 years ago
to: eagle.support.eng
re: which capacitors are surface-mount?
Thu 10/29/2009 3:26 pm
Is there some way to tell the difference between the surface mount
capacitors and the through-hole things in the library? I mean am I
missing something obvious?
j.g. owen * * * * * * * * * * * * * * * * * * *
web:   http://owenlabs.home.att.net/
email: owen_bda4@yahoo.com
    basically, the packages are appended to the "C-" name of the device. SMD
    packages are numbers like 1206 or 0603 while through hole ones have
    dimensions like 060x050. also in the US we space things on 25mil or
    50mil grids while everyone else uses metric grids, so you should pick a
    package that fits the measurement system you are using.
    if you scroll down in the library tree of the control panel, you can see
    all the packages. clicking on one will bring up its information.
