EAGLE User Support (English) drill data generation & update
  • Replies 12 replies
  • Views 2227 views
When processing drill data in preperation to generate gerber outputs, I have
not yet found a way to automatically update the drill table in Options ->
Set -> Drill.   Clicking the "SET" button on the Drill table does
automatically extract drill sizes from the current project, but does not
sort them in increasing diameter (I would prefer it did).  But even if it
did sort them, it is still a manual process.  I can't even find a way to
execute that "SET" button command through a .ULP script.
Am I missing something?   Seems that matching the Drill Table
(options->set->drill) with the ULP-generated Drill Legend should be a
single-step process, right?
I'd be happy to update the drill-legend ULP to do this, but can't find any
ULP hooks to do it.
thanks,
..dane
    Linked below is what I consider to be 'release quality.'  I have run it
    through
    several paces of testing and it seems to be working nicely.  I have also
    submitted the updated file to the ULP folder on CadSoft's website.
    Link:
    http://sites.google.com/site/audiodane/home
    Don't you know, the MOMENT you release something to the public, the next
    time you go to use it, it's broken!
    For some strange reason the old exit() mechanism stopped working, causing it
    to no longer execute the generated script (that actually builds the legend).
    I honestly never understood how it worked in the first place, but either way
    it's now been updated to use an explicit call to 'exit(...)'.
    Link above has been fixed...
    sorry for the glitch,
    ..dane
    I have spend the past several hours pouring over the drill legend ULP, and
    believe I have fixed it so that it properly matches symbols to the drill
    table.
    through
    Link:
    Originally based on Christian Bohrer's older DRILEGEND.ULP v2.01 (from
    2002), this updated version has the following changes:
    - Modified to no longer require sorting of, or removing unused drills from,
    the EAGLE drill table (fround in >Options>Set>Drill).
    - Modified to notify the user if the EAGLE drill table is incomplete
    (missing drill data); ULP will prompt the user to execute the Drill Set
    command (>Options>Set>Drill>Set) and then re-run the ULP.
    - Modified Legend -> MM to default to off (0)
    - Modified Holes -> Non-Plated to default to LAST
    - Modified Holes -> Unit Precision to default to off (0)
    - Modified Outputs -> Generate Rack File default to on
    - Modified Outputs -> Generate Rack File now forced to same folder as board
    (.brd)
    - Modified Outputs -> Default Unit to INCH
    - Added "About" Tab
    I hope others find these changes to be as useful as we do.
    cheers,
    ..dane
    However it is useful on the FAB drawing. This is used for the FAB house
    to quote, and check the board.
    I've never had a complaint or a problem getting a quote when I sent just
    sent the normal .drl, .drd, and .dri drill files to a board house.
    We, too, send the normal .drl/etc files to the fab house, but also include a
    reference drawing layer that includes the board outline and symbolic drill
    data (with a legend).
    Whether or not this is absolutely necessary is somewhat beside the point;
    the fact that some companies (like the one I work for) have this data
    generated as a part of the procedure is a reality.  Whether or not this file
    is used in today's environment I cannot answer.  It may be there for
    historical purposes, but it is there nonetheless.  That may seem like a
    silly answer to some, but those who work for companies with set procedures
    acknolwedge that reality.
    It is also part of the documentation that I deliver to my customers.
    Just give them the .dri file if they even care.  There is advantage in not
    having redundant information in different places and different formats.
    First, they could get out of sync by accident.  Second, someone on the
    other end has to worry about which is the real data, and possibly check
    that the multiple specs match.
    It seems you are making this too complicated.
    Which is why a single ULP that does both drill rack and drill legend is
    useful.  No more out-of-sync data.  We don't use the DRILLCFG.ULP that you
    describe.  Up until last night we have used Christian Bohrer's DRILEGEND.ULP
    (v2.01), which did both the drill rack and the legend, but admittedly was a
    headache to constantly have to get Eagle's drill table (option>set>drill) in
    the proper sorted sequence..  I've simply updated Christian's old script to
    fix some problems with the legend generation aspect.  Very useful for us,
    and I suspect for a few others also.
    cheers,
    ..dane
    Jamesm wrote on Fri, 11 December 2009 11:34
    This is used for the FAB house to quote, and check the board.
    Ultimately their process is going to use the machine readable files anyway.
    They probably ignore what you write on your drawing and go with the
    automated process.  The Gerber and drill files specify the boards quite
    well.  You don't need a drawing at all unless there are special milling
    instructions and the like.  Usually all you need is a notes file that
    specifies the board thickness, copper thickness, finish, etc, but there is
    no reason to include drill information on that.
    I agree, the drill legend is not too useful on an Assembly drawing.
    Regards, James
    -behind every good computer...is a jumble of wires 'n stuff.
    Jamesm wrote on Fri, 11 December 2009 10:20
    The problem for me is when I create a drill legend in my fab drawing.
    If the drills are not SET before you run the upl, the drill legend is
    not correct.
    Interesting, since I've never had anyone ask me for a "drill legend".  I do
    include the .drl and .dri files in the PCB fab package.  The .drl file
    lists the drill sizes in machine readable form, and the .dri file provides
    drill overview information, including the drill sizes, in human readable
    form.
    The drill diameter information is not much use to assemblers, so I don't
    see what good it does on the assembly drawing.  Any information people
    don't use is just clutter and hurts rather than helps.
    If the drills are not SET before you run the upl, the drill legend is not
    correct.
    Regards, Jamesm
    dane wrote on Wed, 02 December 2009 22:34
    have
    not
    it
    to
    I'm not following what you're trying to accomplish.  To "process drill data
    in preperation to generate Gerber outputs", you usually run the DRILLCFG
    ULP.  This makes the .drl file, which contains the list of drill sizes
    used.  The excellon CAM processor job then uses this drill list to create
    the .drd drill data output file.
    I don't see what any of this has to to with the SET comand or why it
    matters what is in the pulldown list of drill sizes (which is the only
    thing that list sets as I understand it).  By the time you run the CAM
    processor, all the drill sizes have been determined by whatever means and
    you shouldn't be trying to change them at that point.  You can't just go
    changing hole sizes after the fact without problems.  If you make the holes
    larger than intended in the library package, it could cut into something
    else or make the ring too thin.  If you make it smaller, it might be too
    tight for a part's leads.
    table.  I need to run some more tests, but it looks like I might even be
    able to catch when you're drill table doesn't have all the drills you need
    and can prompt to you go execute the options-set-drill-set command (since I
    still don't know how to execute that command from within a ULP).
    I've got about a dozen boards to get out the door tomorrow, which is why I
    spent several hours tonight trying to patch the script to make my life much
    easier regarding drill data.  I will be testing it tomorrow and if it seems
    to pass my tests I will post it here for a more broad review.
    I have NOT attempted to "clean up" all my changes to the ULP but will try to
    do so somewhat before I submit it for public verification.
    Hopefully this will prove solid and be useful for everyone.
    ..dane
    Did you ever discover how to update the Drill sizes from inside a ULP?
    No, unfortunately.
    I'm encountering this again tonight; I have about nine PCB's that I'm
    processing tonight and I have to manually go update the drill settings for
    each board, each time I want to generate gerbers.  It's quite frustrating!
    If I could setup the drill data from within a ULP, then I could adapt the
    drill legend generator ULP to incorporate that step automatically so that
    everything is consistent.
    CadSoft-- any way to better automate this task?
    thanks!
    ..dane
