EAGLE User Support (English) Air Wires are not showing
  • Replies 15 replies
  • Subscribers 186 subscribers
  • Views 4951 views
Collins
Collins over 3 years ago
I have taken an existing Eagle design and added some components and signals to the schematic. When I go to the PCB file, which is always opened with the schematic for back annotation, the parts have been placed but there are no air wires shown from those parts. How can I fix this?
  • Collins
    0 Collins over 3 years ago in reply to dougw
    Thanks Doug. I did use the nets tool, and they were connected, but the Unrouted  layer was turned off. Turned it on and all set now...
    0 dougw over 3 years ago in reply to shabaz
    I meant you can draw lines that are not connections even though they look like a correct schematic. Wires and nets both make net connections. The Net tool is slightly more "automatic" and requires less precision.
  • Collins
    Thank you dougw and shabaz for your help.
  • Collins
    0 Collins over 3 years ago in reply to shabaz
    Thank you for the suggestion, it is a hobby of sorts but I want to learn and use Eagle.
  • Collins
    0 Collins over 3 years ago in reply to Collins
    Well look at that!. Yes, the unrouted layer had been turned off. Jumping into an existing design as a novice has been a challenge.
    0 shabaz over 3 years ago in reply to Collins
    If it's a hobby project, a possible option could be to move to KiCad. It has excellent EAGLE import capability, and KiCad is easier for beginners. I can recommend some web links and videos if you need that.
  • Collins
    I will check the unrouted layer.
  • Collins
    My experience with Eagle is very limited, but with the help of some EAGLE tutorial videos I am gaining.
    +1 shabaz over 3 years ago in reply to Collins
    Yes that sounds correct. That was going to be the next thing I was going to ask : )
    Bit of an unlikely thing, but has the "Unrouted" layer been switched off by accident? That would prevent them being shown.
  • Collins
    If I drag the component symbol the net wire moves with it, so it should be connected....correct?
