EAGLE User Support (English) Air Wires are not showing
  • Replies 15 replies
  • Subscribers 179 subscribers
  • Views 4233 views
Collins
Collins over 3 years ago
I have taken an existing Eagle design and added some components and signals to the schematic. When I go to the PCB file, which is always opened with the schematic for back annotation, the parts have been placed but there are no air wires shown from those parts. How can I fix this?
  • Collins
    Collins over 3 years ago in reply to Collins +2
    Well look at that!. Yes, the unrouted layer had been turned off. Jumping into an existing design as a novice has been a challenge.
    dougw over 3 years ago +1 suggested
    Be sure the connections on the schematic are properly made with "wires" not lines. The PCB will only show air wires if they are first connected on the schematic.
    shabaz over 3 years ago in reply to Collins +1 verified
    Yes that sounds correct. That was going to be the next thing I was going to ask : ) Bit of an unlikely thing, but has the "Unrouted" layer been switched off by accident? That would prevent them being…
  • Collins
    0 Collins over 3 years ago in reply to Collins
  • Collins
    0 Collins over 3 years ago in reply to shabaz
    Thank you for the suggestion, it is a hobby of sorts but I want to learn and use Eagle.
  • Collins
    Thank you dougw and shabaz for your help.
    0 dougw over 3 years ago in reply to shabaz
    I meant you can draw lines that are not connections even though they look like a correct schematic. Wires and nets both make net connections. The Net tool is slightly more "automatic" and requires less precision.
  • Collins
    0 Collins over 3 years ago in reply to dougw
    Thanks Doug. I did use the nets tool, and they were connected, but the Unrouted  layer was turned off. Turned it on and all set now...
