EAGLE User Support (English) Eagle used as a file viewer
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 666 views
autodeskguest over 15 years ago
We have only one designer working with eagle at this point. We do allow some
of our bench techs access to the files for troubleshooting. Those stations
are running the freeware version. All the design files are on a network
server.
Since these stations are supposed to be read-only, is there a way to lock
the save function so that there is no chance a file will be accidentally
corrupted?
If this is not an option, the next best option is to make a local copy of
the network design files (with a macro) and point the tech's copy of Eagle
to work off of the local copy.
Does anybody see a use for a 'Viewer' that will protect the unskilled casual
user from themselves (and the wrath of management)?
tia - Oppie
  • kcadsoft
    kcadsoft over 15 years ago
    some of our bench techs access to the files for troubleshooting. Those
    stations are running the freeware version. All the design files are on a
    network server.
    lock the save function so that there is no chance a file will be
    accidentally corrupted?
    of the network design files (with a macro) and point the tech's copy of
    Eagle to work off of the local copy.
    casual user from themselves (and the wrath of management)?
    Why don't you just give those people only read access to those files?
    After all, they could just as well delete or overwrite them from any
    other application.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:hjpnh8$jc3$1@cheetah.cadsoft.de...
    other application.
    Klaus Schmidinger
    Sounds reasonable to set the network permissions for that network resource.
    Unfortunately we outsourced our IT and now it takes an act of the All-Mighty
    to get changes made.
    All things considered, my alternate idea to write an OS batch file that
    copies the .sch and .brd files locally for opening might be more do-able.
    Are any other files necessary to effectively open an existing design? Just
    want to copy the minimum needed files.
        Regards - Oppie (Robert Oppenheimer)
  • kcadsoft
    <snip>
    other application.
    Klaus Schmidinger
    resource. Unfortunately we outsourced our IT and now it takes an act of
    the All-Mighty to get changes made.
    Well, thats what you get in return if you try to save some money image
    do-able. Are any other files necessary to effectively open an existing
    design? Just want to copy the minimum needed files.
    The .sch and .brd files should be enough.
    Klaus Schmidinger
    network server.
    tia - Oppie
    How about keeping a PDF of each file in a separate folder?  Maybe you
    can write a tiny ULP that creates the PDF and then exits Eagle.  Teach
    your staff to run the PDF instead of exiting Eagle.  Just a thought.
    Robert
    "Robert A. Rioja"
    How about keeping a PDF of each file in a separate folder?  Maybe you can
    write a tiny ULP that creates the PDF and then exits Eagle.  Teach your
    Robert
    Yes, we started that way but found that searching for text labels, zooming
    and layer control was far better done in Eagle directly.
    I also maintain copies of all the artwork files imported into GC-Prevue so
    that the techs have a copy of exactly how the artwork was released. Gone are
    the days were it was a matter of keeping a raw board for tracing out
    possible faults.
    - Oppie -
    you may find that if you make the file read-only before you upload to
    your server, it may stay that way. you batch automate this to create
    seperate workshop and reference directories on the server.
    IOW a "working copy". Did you consider using a version control system
    like subversion, git etc.? These are made to work with "working
    copies" and you can set access rights.
    In addition to sch and brd you might consider to get the epf file.
    Maybe you want to pass the epf file path to Eagle. See my old posts
    about this topic to get suitable path settings in Eagle, e.g. "Re:
    Announcement: EAN-02 :: Managing EAGLE Directories" in
    eagle.userchat.eng, 2009-01-29
    <news:3om2o41kklqnltq26a79usu3o3dha2barq@news.cadsoft.de>
    Oliver
