EAGLE User Support (English) Can't stop the autorouter
  • Subscribers 178 subscribers
  • Views 1478 views
CasaDelGato
CasaDelGato over 15 years ago
Occaisionally, when I'm using the autorouter, I notice it taking a
LONG time, and I see that I've poorly positioned some part.
So I've tried clicking on the STOP button.
It stops the router, I move the part, BUT when I restart the
autorouter it puts my component back where it was, restores the traces
i've ripped up, AND resumes the autorouting where it was stopped
previously.
Is there any way to abort the autorouter so it won't restart where it
left off last time?
I want it to start FRESH, as I'll have moved things and ripped up
traces.
    autodeskguest over 15 years ago
    John Lussmyer wrote on Fri, 19 February 2010 11:39
    left off last time?
    Delete the autorouter restart file.
  • CasaDelGato
    On Fri, 19 Feb 2010 16:27:58 -0500, Olin Lathrop <eagle@embedinc.com>
    left off last time?
    So, whats' the point of being able to stop the auto-router?
    You have to go delete a temp file to be able to DO anything after
    stopping it.
    <Cougar@CasaDelGato.Com> wrote in message
    news:1mjun51g976h7vas69ntoi4d75slj81v3a@4ax.com...
    left off last time?
    stopping it.
    if you would look carefully on the autorouter window, second time you
    run-it, you would get your answer
    John Lussmyer wrote on Fri, 19 February 2010 21:54
    To stop it so that Eagle can do something else, obviously.
    stopping it.
    No, only if you want to do certain things.  If you want the autorouter to
    restart where it left off, then you don't want to delete the restart file.
    left off last time?
    stopping it.
    What Silviu means is just to remove the hook on "continue existing job"
    in the AR image
    Gruß / regards
    Joern
