EAGLE User Support (English) Open Sch & Brd files together
  • Replies 72 replies
  • Subscribers 190 subscribers
  • Views 9285 views
k.portman
k.portman over 16 years ago
Is there a way to open an existing Sch & Brd file together, by default.
When I double click either Sch or Brd file name on the Eagle Control
Panel it asks "Do you also want to load xxx.brd?" (or xxx.sch). I always
respond Yes, sofar never had a need to respond No.
Is there a eaglerc.usr setting to force (or make as default behaviour)
the opening of Brd & Sch files together. If not, could it be
implemented. Much requested for!!!
Kim
  • kcadsoft
    kcadsoft over 16 years ago
    Implemented for one of the next releases.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    Ok, it's clear for me:
    You hide everything that bothers you. image
    "Silviu Epure" wrote:
    Then you can set a view filter in Total Commander to see only the file
    types you want to see. That's what you asked for, isn't it?
    From a file manager I want to see all files. This for is a "file manager".
    So what do you think the configurable and switchable view filters in
    the file manager are intended for?
    1. If you were not aware of this, Eagle Control Panel DOES show some pdf
    files in tree. (It has a filter, but it's not so good in hiding pdf
    IMO Eagle should not display it.
    That's also my comment you requested in your other posting.
    Oliver
    "Oliver Betz" <obetz@despammed.com> wrote in message
    news:02sko598h1681quh34cqi7u0sakcq0e174@news.cadsoft.de...
    Please, comment the attached image.....
    Or do you like to see only what make you happy (3 files shown, and 10k files
    hidden, and then wander "where is the free space of the HDD?!")
    But a full folder is a full foder no matter what file browser you use.
    That's not the question, you suggested the Eagle Control Panel to show
    a certain set of files, and that's what a good file manager already
    does.
    files...)
    2. what it's your opinion about files with arbitrary extension, files that
    can be created with ulp's in project folder, and are perfectly visible from
    CP?!!!
    2. My concept is not "program oriented", but "project oriented"
    Where is the difference?
    Realy do you consider there is no difference?
    3. and be honest... would you be bothered if Eagle could open pdf with
    external application?
    Yes.
    Why? because it will know how to properly open a file that now it's
    displayed in CP, and it's opened with integrated text editor?!
    It is allready support writing pdf's....
    So Eagle should also contain/support a Gerber Viewer, picture viewer
    etc?
    A custom filter shoud satisfy everybody. Default operation should be: sch,
    brd, lbr, scr, ulp displayed, other files not. User (like me) could add
    extensions in eaglerc.usr files, so this files could be passed to OS to be
    opened.
    autodeskguest over 16 years ago in reply to autodeskguest
    1. I do have a usefull file manager (totalcmd), and I know how to use-it.
    does.
    Yes.
    etc?
    Oliver
    "T G" <fightspammers@gmail.com> wrote in message
    news:hm9rgo$1rq$1@cheetah.cadsoft.de...
    Actually one person did request a pdf viewer to be built-into Eagle...
    I admit, I'm that person, but it was just an idea (to display content of pdf
    in the "information" area of the Control Panel)
    But implies hard work from developpers, for ... almost nothing.
    So I also admit it's not a good idea.
    news:hm9qs0$vc5$1@cheetah.cadsoft.de...
    Why complain about 6 windows?
    Because it could be better! It's not this the scope of the forum, where
    developpers find user's needs ?
    That said, I agree Eagle should have tabs, suggested it months ago.
    I know, this is an other discution, on other thread
    I highly disagree it should include a pdf viewer built in.
    agree with you. It was a bad idea to create a built-in pdf viewer, by
    electronics developper. There are many goods applications for this purpose.
    or did they say that since EAGLE can generate a pdf file, it might as
    well be able to display one? well, that might be taken either way,
    especially if you did not get the whole context.
    and stop hiding files in the
    control pane - which is simplifying the code. if this is untrue, I
    I will be very unhappy if no file filtering is available. The best
    arrangement is to provide a customizable filter, which is not hard at all.
    perhaps your ignorance of programming into the debate. please quote for
    me where I, or anyone else, has asked for EAGLE to be aware of and
    handle different file types. right, we only asked that they be opened in
    the native application, not EAGLE, you misunderstood us. when we say
    open, we mean "from the control panel", not "by the EAGLE application".
