EAGLE User Support (English) Linux: opening old projects report inconsistant board and schematics due to net name conversion of !name.
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 766 views
Conversion of net names has gone wrong. See screenshot:
In case it gets stripped, multiple lines similar to:-
        Different connections on D4 pin AK and pad 3 (!SICK/\!SICK)
Not sure when this crept in. Maybe v5.6.
Martin Hodges
Senior design engineer
Nevion AS
    autodeskguest over 16 years ago in reply to autodeskguest
    Martin Hodges schrieb:
    I will send you the design files which have been problematic.
    The files you sent me already had been converted to V5, use valid names
    and are consistent. So I can't really test anything with them...
    I have opened more old designs with v5.8 and they seem fine. This confirms
    that the conversion is done correctly from older designs.
    It may be that I have opened and saved the problem design with a version
    that incorrectly modified the net names.
    I think that must have been the cause. As I mentioned, that bug has been
    fixed meanwhile - I assume that you unluckily opened and saved these
    files with one of the buggy versions inbetween.
    From the history notes, V5.6.1 fixed handling of backslashes, and 5.7.1
    fixed handling of exclamation marks. So your problem was probably caused
    by opening your V4 files with a version prior to 5.6.1.
    Tilmann
    Martin Hodges wrote:
    Sorry about the long subject. Searching can get tedious when one has to
    open every post that might have something to do with ones problem.
    Note that it also gets uncomfortable if the subject doesn't fit into the
    header line... image
    Ubuntu 8.04 LTS i386
    Eagle 5.80
    Ok, you're up to date. Do you still have the original (older, V4) files,
    for a test? If you open them directly with the current version, signal
    names should be converted correctly (as mentioned, that bug has been
    fixed). If they are not, please report it here (or in betatest).
    The files have been opened and I have written 'wr' in the command line
    thinking that this would save the file in the new format/structure.
    I have now tried to update the file with a new frame in v5.2. This version
    imports the original design without coughing up errors about
    inconsistancies. I update the drawing frame to a new one with global
    attributes and a frame.
    I save the design and reopen the design with the beta v5.81 (this allows
    both versions to peacefully coexist.) Now the design is still consistant.
    I guess that the structure was not re-written unless a largish change was
    introduced.
    So to sum up:
    The older linux versions of v5 import fine.
    The current linux version does not.
    However, if you have made changes meanwhile, you'll probably have to
    rename all those signals/nets manually. Hopefully they aren't too
    many... (Once the automatic conversion to the V5 nomenclature has been
    done, there is no chance to fix it with an even newer V5.)
    that incorrectly modified the net names. It is also good to have a work
    around.
    Open with an older version, 5.2 for example. Update one of the libraries,
    this may only work if the library to update introduces changes. Save the
    design.
    Tilmann
    Martin Hodges
    Nevion AS
    Eagle 5.80
    introduced.
    So to sum up:
    Tilmann
    Martin Hodges
    Nevion AS
    Sorry about the long subject. Searching can get tedious when one has to open
    Eagle 5.80
    Tilmann
    It got stripped. Try with a monochrome image.
    Eagle 5.80
    Locale settings
    LANG='nb_NO.UTF-8'
    LC_MESSAGES='en_GB.UTF-8'
    Should I check the latest beta?
    Same result on Debian Lenny i386
    Eagle 5.81
    Martin Hodges
    Nevion AS
    Eagle 5.80
    Locale settings
    LANG='nb_NO.UTF-8'
    Martin Hodges
    Nevion AS
    Which version are you using?
    This should have been fixed in the current version.
    Tilmann
    P.S. Please use shorter subjects...
    Martin Hodges
    Nevion AS
