    • Avnet Boards Community
EAGLE User Support (English) Newbee: howto make device with 2 GND pins
  • Replies 12 replies
  • Subscribers 176 subscribers
  • Views 886 views
Former Member over 15 years ago
Like SOT223 a device having 2 pins internally connected in the device.
Sot224 pin 2 and 4(cooling pad) are the same.
I supposed that connecting  one pin it is also connected to the other.
However, on the board a airwire still remains. This is also true for a
sot223 device from the library.
I tried the mailto:GND@1 etc. naming, but seems not to work.
What am I doing wrong?
  • esilviu
    esilviu over 15 years ago
    "Rens" <rens.kessener@onsbrabantnet.nl> wrote in message
    news:hr22dk$oue$1@cheetah.cadsoft.de...
    in the symbol, name one pin GND, and the other GND@1
  • esilviu
        I was in a hurry with previous answer.
    I now see your problem: You defined the pads in the right way, but you are
    bothered by the fact that Eagle wants you to connect those 2 pads with a
    wire on board.
        From all I know, it's not possible to have 2 pins on the same signal,
    and tell Eagle that those pins are connected together IN the IC. So just
    ignore that airwire. (This is the way I would do.)
    autodeskguest over 15 years ago
    Am 25.04.2010 20:41, schrieb Rens:
    Eagle does not know internal connections. So the rule is one pin for one
    pad. Some SO8 transistors have four drains which are internally
    connected. They are named D, D@1, d@2, D@3 in the library in this
    example. It would be ok, if you connect just one of these pins in the
    schematic and eagle would do the same in board.
    BUT, why should a manufactorer add more pads, if one is enough?
    Because the chip is connected to the pads with bonding wires and one
    wire is not thick enough to carry the amount of current specified in the
    data sheet. So two or more connections are used in parallel to carry the
    current. So you should see that all equal named pins are connected
    externally to avoid a "slow blowing fuse" device.
    Gruß / regards
    Joern
    Former Member over 15 years ago in reply to esilviu
    Thanks, That helps. Took me 2 days of reading and trying.
    Advantage is that while doing that I learned many other things as a newbee.
    Thanks again. Rens
    Former Member over 15 years ago in reply to autodeskguest
    Thanks, but I figured that out already.
    My problem was (with a TLE4242) that I had to cross another wire
    to solve the airwire by a connection from pin 4 (GND) to the Thermal Pad
    (also GND).Ignoring the airwire is the best option I understood.
    Regards, Rens
    What is the significance (if any) of using the "@" symbol in the example
      above.
    BTW, what I do in this situation is have GND1, GND2, GND3, .... as pin
    names on the symbol and then connect them all independently to "GND" on
    the schematic.  Works well.
    one pad. Some SO8 transistors have four drains which are internally
    the data sheet. So two or more connections are used in parallel to
    carry the current. So you should see that all equal named pins are
    connected externally to avoid a "slow blowing fuse" device.
    above.
    The part following the '@' is not shown so that each looks like the same
    label pin.
    On Mon, 26 Apr 2010, Michael Sansom wrote to us saying :
    example  above.
    The @ symbol in a pin name introduces a hidden suffix, so that it allows
    all the pins to appear on the schematic as just "GND". It also means the
    net table treats them as just "GND", so they all get automatically
    connected to the GND net.
    Yes, that works, but it requires you to explicitly connect them all,
    shows a fake ordering of ground connections, and usually doesn't match
    the data sheet. It's very reasonable for the tab of a SOT223 FET, where
    you may actually want to distinguish between the tab and the middle pin
    because you only actually need to connect one of them, but for a 64 pin
    LQFP chip with 8 ground pins, you want them all to be the same to ensure
    they're all connected (like the data sheet says they must be).
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    Am 27.04.2010 00:24, schrieb Gary Gofstein:
    above.
    label pin.
    ...and gnd1, gnd2 or vdd1 and vdd2 etc. are usually different nets if
    you use an isolation amplifier for example image
    Gruß / regards
    Joern
  • dukepro
    dukepro over 15 years ago
    Don't forget thermal considerations.  Each pin will carry some heat away
    from the die.  So connecting these externally is essential if you expect
    to meet the theta-ja specs.
    Enjoy,
        - Chuck
