    • Avnet Boards Community
EAGLE User Support (English) OK to have brd dimension NOT to start at origin, that is, (0,0)?
  • Subscribers 175 subscribers
  • Views 501 views
unebonnevie
unebonnevie over 15 years ago
I have dilemma.  My brd design has to be 0.1 in. spacing, that is,
2.54mm spacing.  As you can see from the attached image, I can't have
the board dimension starts at the origin, the bottom left corner.  The
reason is that the red wires just under the green via would nearly touch
the bottom edge of the board, thus, violation DRC rules. If I move the
via up the next 0.1 in., then there is no DRC rule violation, but I have
a big gap now.  So, what I do now is moving origin, so that I won't have
a gap and still not having any DRC error.
As far as I know, that should be fine, correct?  At the end of the day,
it's the board's dimensions, regardless of its origin, is what counts?
  • unebonnevie
    On 5/23/2010 12:06 AM, AL wrote:
    I have dilemma. My brd design has to be 0.1 in. spacing, that is, 2.54mm
    spacing. As you can see from the attached image, I can't have the board
    dimension starts at the origin, the bottom left corner. The reason is
    that the red wires just under the green via would nearly touch the
    bottom edge of the board, thus, violation DRC rules. If I move the via
    up the next 0.1 in., then there is no DRC rule violation, but I have a
    big gap now. So, what I do now is moving origin, so that I won't have a
    Sorry to clarify...It's not a via I that I wrote previously.  It's one
    of the holes of one of the header pins.
    Former Member over 15 years ago
    AL[1
    wrote on Sun, 23 May 2010 01:06]Hi,
    touch
    have
    have
    You can make your board any reasonable size/shape you want and start it
    anywhere you need to (assuming you have the Pro version). The relative
    dinemsions between the components and pads will remain the same and on the
    grid regardless where you put your board outline. You can shift your board
    to allow for traces and to pass the DRC and it should be fine.
    Putting a corner at the origin is more for convenience than anything else.
    autodeskguest over 15 years ago
    AL wrote:
    Perhaps I am not understanding the problem.   Have you tried setting an
    alternate grid? (See Help->Grid)  If you define an alt grid which is a
    small fraction of the normal grid unit you can selectively use it to
    adjust placement by very small amounts if needed ....just hold down the
    alt key while moving a component/trace.
    jiml
  • unebonnevie
    On 5/23/2010 9:17 AM, Jim Littlefield wrote:
    AL wrote:
    touch the bottom edge of the board, thus, violation DRC rules. If I
    move the via up the next 0.1 in., then there is no DRC rule violation,
    but I have a big gap now. So, what I do now is moving origin, so that
    I won't have a gap and still not having any DRC error.
    jiml@:  The pin headers have to be in 0.1 in. spacing, because they go
    into the breadboard. Because of that, it has to be in 0.1 inch increments.
    jiml
    AL wrote:
    jiml
    The spacing between the pins in the header is controlled by the library
    package definition.   You can move the entire connector on the alt grid
    without affecting the pin spacing within a single connector.   If you
    are trying to keep a 0.1 spacing between different headers you can still
    do this by clicking the info button and manually assigning coordinates
    which are an integer multiple of 0.1 inch units from the position of
    another reference connector.    This will keep the headers on 0.1 grid
    w/o having to keep them so wrt the PCB edge.
    jiml
  • unebonnevie
    increments.
    jiml
    package definition.
    Nope, not talking about the space between the pins.  That's 0.1 inch for
    sure.  I am talking about entire header has to be at 0.1 inch increment
    in order for the entire header to be plugged into the breadboard nicely.
    without affecting the pin spacing within a single connector. If you are
    trying to keep a 0.1 spacing between different headers you can still do
    another reference connector. This will keep the headers on 0.1 grid w/o
    jiml
