EAGLE User Support (English) Exporting pad data for Phoenix X-ray machine
  • Views 1195 views
autodeskguest over 12 years ago
Hi all, we have Phoenix Micromex 180 x-ray machine for PCB inspection at
my workplace. Its software can greatly automate creation of new
inspection programs for boards, but as an input, it requires data with
component and pad coordinates. Two separate files are needed: 1. one
which lists all components, their names, package type and coordinates.
2. one which lists pad shapes and coordinates (relative to package's
origin mark) for all package types used on a board. Here are shortened
examples of needed file contents:
Component file:
  1. Board dimensions: X size, Y size, layer height
DIMENSIONS: 130 90 1.6
  1. RefDes    PackageID    X-shift    Y-shift    ROT    PinCount
Side    MountType
C7               27    30    50    0    2    TOP       THROUGH
R7               26    121    51    0    2    TOP       THROUGH
V18             19    23    40    0    3    TOP       SMD
C58             14    99    7    90    2    TOP       SMD
V30             16    6    63    0    2    TOP       SMD
V15             19    23    20    0    3    TOP       SMD
C8               27    30    45    0    2    TOP       THROUGH
C43             13    104    77    0    2    TOP       SMD
Pad coordinates file:
PackageID    label    X-shift    Y-shift    Rotation    Width
Height    Shape
6    1    -0.65    0    0    0.9    0.7    RECTANGLE
6    2    0.65    0    0    0.9    0.7    RECTANGLE
15    A    -1.7    0    90    1.8    1.4    OBLONG
15    K    1.7    0    90    1.8    1.4    OBLONG
22    A1    -12.06    12.06    0    0.6    0    ROUND
22    A10    -0.63    12.06    0    0.6    0    ROUND
22    A11    0.63    12.06    0    0.6    0    ROUND
22    A12    1.9    12.06    0    0.6    0    ROUND
22    A13    3.17    12.06    0    0.6    0    ROUND
27    1    -1.25    0    0    1.3    0    ROUND
27    2    1.25    0    0    1.3    0    ROUND
Obviously, the most "clean" solution would be to write my own ULP to
generate the files. But that would be very time-consuming, so I want to
try some alternative solutions before I do that. I figured the component
file could be easily obtained by editing the standard Eagle partlist,
for example by a relatively simple MS Excel macro. But I found no way
how to obtain the pad data, or at least not in the format needed. I know
there is export-ict-netlist-pad-coordinates.ulp, but this one exports
the pad coordinates relative to the entire board, not relative to
package's origin mark. And the information about pad shape is missing
completely in it.
So my question is: *is there some existing ULP which can produce such
pad data*?
Just in case you were interested, here is some info about our x-ray
machine:
http://www.ge-mcs.com/en/radiography-x-ray/micro-and-nanofocus/micromex-dxr-hd.html
http://www.element14.com/community/message/93087#93087
    In case anyone was interested, I tasked one of my students to create an ULP that does exactly this. It's named "export-phoenix-x-ray-cad-data.ulp" and can be found on Cadsoft's ULP download page.
    Perhaps more importantly, the same student also created free "ODB++ to Phoenix X-ray CAD data converter", which allows you to generate the Phoenix CAD data from many other PCB layout editors (Altium, Allegro, Orcad, Protel, Expedition...), as long as they have ODB++ export. The converter runs in Java, and you can download the latest version from his Github repository (you only need the ODBtoRTG.jar file):
    https://github.com/popelavojtech/ODB-to-Phoenix-X-ray-CAD-data-converter
    The converter itself is simple to use, but you may encounter several problems while generating the ODB++ data, particularly on Cadence products. So I created an English help page, which can be found here:
    http://odbconverter.xf.cz/
    The CAD data should work on all Phoenix/GE machines that run the Xact software. Currently, it's Phoenix Xaminer, Micromex and Nanomex, though there may be others I'm unaware of. Note that only Xact Pro version currently supports CAD data import.
    If you have any questions of feature requests, please contact the student directly. While I was his supervisor (and betatester), he is the sole creator of the converter itself.
    Component file:
    Side    MountType
    Height    Shape
    completely in it.
    Hi Caleb
    This is outwardly an easy ULP but challanges arise when producing files
    with the classifications used in your examples.
    Do you have the file specifications you can post here?
    Can you post real data files?
    Some of the questions that need answering, for clarification, are:
    What is the difference between rectangle and oblong?
    Is the measurement always millimeter or can that change?
    Is the width of the ROUND pad its diameter?
    If a device has both SMD pads and through hole mounting should it be a
    MountType SMD or THROUGH?
    Does Phoenix expect PackageID to be numeric?
    Is the file Tab delimited or comma delimited or something else?
    How does Phoenix handle odd shaped pads when the pin does not align with
    a SMD pad that seeds the odd shape? It contacts the associated polygon
    or wire. Does it even matter?
    Are the dimensions a rectangle( with thickness) the board fits into no
    matter what the board shape?
    Are the 'Side' options TOP and BOTTOM?
    In Eagle an SMD pad is a rectangle with  a portion of rounding. 100%
    rounding makes a square pad round. So each pad needs evaluating to
    determine which Phoenix classification it resides in. Eagle has
    elongation for Pads.  Elongation is only valid for shapes
    PAD_SHAPE_LONG and PAD_SHAPE_OFFSET and defines how many percent the
    long side of such a pad is longer than its small side.
    So the ULP needs to produce a file in Phoenix speak.
    I was able to create the data for the component file today but the Pad
    coordinates file needs the above questions answered to progress to that
    Warren
    Caleb,
    It is quite simple, I wrote code to do that in the eagle2freerouter.ulp
    and you can lift it out there (around line 445). In this example I use
    functions (pad_sig and smd_sig) to store the data in a string array:
    void read_board_pads_and_vias(void) { // 19-01-28
    // Get pads from the library and vias from the nets, defaults are
    already loaded
         board(B) {
              B.libraries(L) {
                   L.packages(P) {
                        P.contacts(C){
                             if (C.pad) {
                                  pad_sig (C.pad.shape[LAYER_TOP], C.pad.diameter[LAYER_TOP],
                                       C.pad.drill, C.pad.elongation, C.pad.angle);
                             if (C.smd) {
                                  smd_sig (C.smd.roundness, C.smd.dx, C.smd.dy, C.smd.layer,
    C.smd.angle);
              B.signals(N) {
                   N.vias(V) {
                        via_sig(V.shape[LAYER_VIAS], V.diameter[LAYER_TOP], V.drill,
    V.start, V.end);
         return;
    Regards, Robert
    Component file:
    Side    MountType
    Height    Shape
    completely in it.
    pad data*?
    machine:
