EAGLE User Support (English) IDF files and libraries
  • Subscribers 187 subscribers
  • Views 826 views
Hi support,
I'm currently testing the IDF export tool in Eagle 7.3.
I have some question concerning the component dimensions.
I know that I have to add a HEIGHT attribute for each component. But I
can't find which layer is used in the package to determine the width and
length of the component.
Any suggestions? Thanks!
Vincent
    Hi Warren,
    reading the ulp header, i got the 2.2 version coming with my eagle 7.3
    version.
    I don't see in the file any option or configuration concerning the keepout.
    Do you have more information?
    Maybe I can contact the author Marc Battistello.
    BR
    Vincent
    Hi Vincent,
    The latest version is 2.4 which comes with EAGLE 7.5.0. I don't see any
    comments about it being implemented in that version so it looks like
    being able to ignore features on the keep out layers is still on the
    todo list.
    hth,
    Jorge Garcia
    Le 16/03/2016 16:45, Jorge Garcia a écrit :
    Hi Warren,
    this is what I though.
    So if I Want a quite accurate PCB 3D model, I have to limit all useless
    wires and so on.
    My problem is that it also take all polygon, rectangles wires, in the
    Keepout layer. I don't think it is a good idea, because only the body
    (tPlace layer on maybe tDocu) and the pins should be in the IDF package
    don't you think?
    Thanks for your answer.
    Vincent
    Hi Vincent,
    The most recent version of the ULP gives you the option to ignore
    features on the keepout layers if I recall correctly.
    hth,
    Jorge Garcia
    Hi Warren,
    version.
    BR
    Vincent
    Hi Warren,
    wires and so on.
    don't you think?
    Vincent
    Hi Vincent,
    hth,
    Jorge Garcia
    Le 15/03/2016 10:09, warrenbrayshaw a écrit :
    On 15/03/2016 9:45 p.m., Vincent Belloir wrote:
    Hi support,
    Vincent
    Looking within the ULP eagleidfexporter.ulp
    The ULP looks at all the wires, arcs, circles, polygons,
    holes,rectangles in the package.
    //check min/ax for each of
    //circles() UL_CIRCLE - C.x, C.y, C.radius, C.width)
    //holes() UL_HOLE
    //polygons() UL_POLYGON -> wires()
    //rectangles() UL_RECTANGLE - R.x1, R.y1, R.x2, R.y2);
    //wires() UL_WIRE
    The layer is not important as it scoops up all of the above objects no
    matter which layer they are on.
    The resulting width and length is a rectangle deduced from the above
    min x max y (top left)
    to
    max X min Y (Bottom right)
    HTH
    Warren
    Hi Warren,
    wires and so on.
    don't you think?
    Vincent
    Hi support,
    Vincent
    //holes() UL_HOLE
    //wires() UL_WIRE
    to
    HTH
    Warren
