EAGLE User Support (English) 4-Layer setup script?
  • Replies 7 replies
  • Views 839 views
Oppie
Oppie over 10 years ago
I'm still plodding through the user manual. New design and first time doing
a 4-layer. Setting up all the necessary resources for a 4-layer with all
through vias. Was wondering if anybody might have a setup script that I
could review?
Been using the design rules
"eC_4Layer_PClass6_BaseCopperO18-I35_eCDefault.dru"
Set up used layers and some of the router options. Think I've almost got it
but wanted a reality check before going on.
TIA - Oppie
    Am 01.04.2016 um 20:55 schrieb Oppie:
    If this is correct, is there a command line way to delete all display
    aliases?
    Define an alias
      DISPLAY = myview 1 2 3 16;
    Delete it:
      DISPLAY = myview;
    Richard Hammerl
    Am 01.04.2016 um 17:09 schrieb Oppie:
    "Richard Hammerl" <support@cadsoft.de> wrote in message
    news:ndlik8$c77$2@baboon.cadsoft.de...
    Am 17.03.2016 um 21:07 schrieb Oppie:
    doing a 4-layer. Setting up all the necessary resources for a 4-layer
    with all through vias. Was wondering if anybody might have a setup
    script that I could review?
    it but wanted a reality check before going on.
    TIA - Oppie
    Usual 4 layer board:   (12*1516)
    What might you recommend for the router settings?
    Might you have a representative .ctl file to share here?
    Hi Oppie,
    as far as I can remember Andreas Weidner once wrote a long advice how to
    create all kind of types of layer settings. Unfortunately I cannot find
    it anymore and anyway I shall not place anything here without his per
    mission.
    Usually he reads here too and will cut in or you can try to contact him.
    Joern Paschedag
  • Oppie
    "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    news:ndmev8$r9f$1@baboon.cadsoft.de...
    Hi Oppie,
    I hope you're doing well. You don't have to fiddle with the autorouter
    settings when you add layers, the default cost factors usually work
    pretty well.
    If you want to do via drops to GND or PWR with the autorouter then you
    may want to check out the attached ctl file. This one is setup to make
    the autorouter drop down to planes.
    hth,
    Jorge Garcia
    Thanks Jorge. Will be looking into that. Still juggling a bunch of things.
    Right now, I've been adding display aliases in BRD. I have all the new
    aliases in a modified version of the mylayers.scr but find that new layers
    are added to the end of the alias list in the brd editor. Would it be
    correct to delete all the aliases and then run the script? One would think
    that the aliases would then order as given in the script. If this is
    correct, is there a command line way to delete all display aliases?
    Hi Oppie,
    pretty well.
    hth,
    Jorge Garcia
  • Oppie
    TIA - Oppie
  • Oppie
    TIA - Oppie
    Richard Hammerl
    I thought so too Richard, but this was one of the DRUs included with V7.5.
    This being my first board project with more than two layers, was seeking
    some advice.
    TIA - Oppie
    Richard Hammerl
