EAGLE User Support (English) Importing dxf layouts int o copper layer
  • Views 603 views
I'm trying to import a copper layout that's been specified by the supplier
of a chip antenna.  In the attached file "untitled.brd", the board outline
is imported from a dxf file without any problems.   In the top right is the
dxf file for the layout that I want to place on top copper.    I can import
the dxf, and move it to where I want it.  The challenge is that I've only
got the outline...and can't figure a way to fill it.
I've considered manually drawing wires to trace the outline...but that
seems like a make work project...especially when the dxf design will likely
need to be tweaked through development. I've tried modifying the dxf file
to turn the line segments into polygons and then using
import_dxf_polygons_v4.ulp, but I literally get "nothing" when I use that
ULP.
I've also looked around to try and find a dxf to gerber converter to see if
I can then import gerbers.  The apps that I could find are REALLY
expensive. No doubt these are great apps for organizations that regularly
manipulate gerbers...but they're beyond my reach.
Any help would be much appreciated!
JohnD
  • omega-5
    omega-5 over 10 years ago in reply to omega-5
    Am 01.04.2016 um 12:23 schrieb Friedrich Bleikamp:
    Hi John,
    I would take a DXF to Script Converter from here
    http://www.cadsoftusa.com/downloads/tools-and-converters
    and edit the resulting script. In the appendix you will find an
    example.
    Hi John,
    sorry, wrong attachment. That should work better.
    Freundliche Grüße / Kind regards
    Friedrich
    ... benutzen Sie nntp://news.cadsoft.de und einen
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • omega-5
    Am 01.04.2016 um 00:32 schrieb John Dolson:
    Hi John,
    example.
    Friedrich
