EAGLE User Support (English) Library Pad Grows when p laced on Board?
  • Replies 30 replies
  • Subscribers 189 subscribers
  • Views 1709 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I have a home-brew device (a couple of slots). In the device manager it
looks like this:
Note that the solder mask along the wire is the same size as the pad
diameter (red & green arrows).
However, when imported into a board, the pads on the large slot change
size?
See red arrow. Both slots are constructed the same way
(2xpadMillTopBottomtStop+bStop)
Why?
Can it be prevented?
Regards, Martin
    autodeskguest over 10 years ago in reply to rachaelp
    On 26.04.2016 13:26, Rachael wrote:
    James Morrison wrote on Tue, 26 April 2016 04:42
    EAGLE's concept of DRC is a mix between dynamic settings that effect
    the design and static rules that get checked.  I would personally prefer
    if they would break those two apart because I think it leads to more
    confusion.
    I agree with this, I would prefer these to be separated out too. DRC does
    stand for Design Rule Check after all!
    Rachael
    Maybe its as easy as renaming the DRC window to "Design & Rule settings"
    or similar image
  • rachaelp
    rachaelp over 10 years ago in reply to autodeskguest
    confusion.
    Rachael
    autodeskguest over 10 years ago in reply to autodeskguest
    Morten Leikvoll wrote on Mon, 25 April 2016 11:10
    On 23.04.2016 18:28, Rob Pearce wrote:
    On 23/04/16 09:55, René König wrote:
    Am 23.04.2016 um 10:21 schrieb Rob Pearce:
    you still want larger values in DRC to override it.
    No, not at all. A check is a check is a check and should not modify
    the
    board. I want the DRC to issue warnings. Then, I'm free to approve
    these
    warnings or rework the part definition in the library.
    I disagree.
    Your absolutist stance is based purely on the presence of the "C"
    in
    DRC. You should stand back and ask yourself, "given that I have a
    set of
    Design Rules, do I want them applied?" I would posit that the
    answer is
    "yes". So then, having defined these rules, "Do I want to check
    against
    them?" Again, probably yes.
    Sure, there may be some corner cases where, for obscure reasons
    of
    perversity, you want to check against a different set of design
    rules to
    the ones you're building to. But that's not the normal behaviour
    of most
    people.
    Just to add to the understanding of the DRC (and rest-rings).
    The DRC is actually a check of the board's manufacturability and you
    should ask (download) the manufacturers settings.
    When it comes to parameters like the rest-rings (also alot of the other
    parameters), these are important for the board manufacturer (not the
    part!) to get the job done right. Too small rest-ring may be too tight
    for the manufacturer's equipment tolerances.
    A pro manufacturer will also run the gerbers through their own DRC and
    give you feedback if there are problems.
    This is related the discussion we had about vias recently:
    http://www.eaglecentral.ca/index.php/m/165366/1f249bff7c718debc0a920f11ebc283e/#msg_165366
    Follow that same line of thinking if you want your pad diameters set in the
    library to be exactly that in your PCB.  EAGLE's concept of DRC is a mix
    between dynamic settings that effect the design and static rules that get
    checked.  I would personally prefer if they would break those two apart
    because I think it leads to more confusion.
    James.
    Order your EAGLE license from Stratford Digital at
    http://www.eaglelicenses.com
    the
    these
    I disagree.
    in
    set of
    answer is
    against
    of
    rules to
    of most
    people.
    James.
    the
    these
    I disagree.
    in
    set of
    answer is
    against
    of
    rules to
    of most
    people.
    James.
    No, not at all. A check is a check is a check and should not modify the
    board. I want the DRC to issue warnings. Then, I'm free to approve these
    I disagree.
    Your absolutist stance is based purely on the presence of the "C" in
    DRC. You should stand back and ask yourself, "given that I have a set of
    Design Rules, do I want them applied?" I would posit that the answer is
    "yes". So then, having defined these rules, "Do I want to check against
    Sure, there may be some corner cases where, for obscure reasons of
    perversity, you want to check against a different set of design rules to
    the ones you're building to. But that's not the normal behaviour of most
    people.
    I disagree.
    people.
    I disagree.
    people.
    I disagree.
    people.
    I imagine a world where we have a second set of rules which get applied
    on auto parameters, and on auto parameters only.
    That's at least what I want (and probably never get).
    Rene
