EAGLE User Support (English) Library Pad Grows when p laced on Board?
  • Replies 30 replies
  • Subscribers 189 subscribers
  • Views 1711 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I have a home-brew device (a couple of slots). In the device manager it
looks like this:
Note that the solder mask along the wire is the same size as the pad
diameter (red & green arrows).
However, when imported into a board, the pads on the large slot change
size?
See red arrow. Both slots are constructed the same way
(2xpadMillTopBottomtStop+bStop)
Why?
Can it be prevented?
Regards, Martin
    autodeskguest over 10 years ago in reply to autodeskguest
    Am 23.04.2016 um 10:21 schrieb Rob Pearce:
    you still want larger values in DRC to override it.
    No, not at all. A check is a check is a check and should not modify the
    board. I want the DRC to issue warnings. Then, I'm free to approve these
    warnings or rework the part definition in the library.
    I imagine a world where we have a second set of rules which get applied
    on auto parameters, and on auto parameters only.
    That's at least what I want (and probably never get).
    Rene
    Rene
    autodeskguest over 10 years ago in reply to mprowe@peritonlane.net
    On 23/04/16 09:08, Martin Rowe wrote:
    Hi Rob,
    Thank you for the detailed explanation. And yes, I understand the
    usefulness of "parametric" design.
    However, shouldn't that be enabled only on the "auto" value in library pad
    diameter?
    If I wanted a pad diameter of "X" (for whatever misguided reason!) by
    defining it in the library, I would have expected to get a pad diameter of
    "X"?
    The most likely reason to specify a pad diameter in the library would be
    to specify a minimum restring for this component - or even a particular
    pad which has either strange-shaped pin or a current requirement -
    without forcing the DRC settings for the rest of the board. As that's a
    minimum requirement, you still want larger values in DRC to override it.
  • mprowe@peritonlane.net
    Hi Rob,
    diameter?
    "X"?
    Not that it matters, you have all helped me understand what I am seeing,
    and I can now work around these "features" image
    Many thanks, Martin
    Hi Rob,
    diameter?
    "X"?
    Many thanks, Martin
    Hi Rob,
    diameter?
    "X"?
    Many thanks, Martin
    On 22/04/16 21:19, Martin Rowe wrote:
    Can't quite grasp the objective or reasoning behind it yet, but maybe it'll
    come as I play?
    Suppose I have a component - perhaps a DIL IC - which I'm using on a
    number of designs. Most of these are professionally produced PCBs where
    production tolerances are very good. I only need small currents here so
    it's convenient to use 12 thou tracks and similar restrings. This means
    I can route tracks between pins for more efficient layout.
    Now I want to use that same component on a board that I'm etching at
    home. Now I'm quite good at home etching so I'll happily use 16 thou
    tracks, but my drilling isn't so great. The restring needs to be at
    least 20 thou here.
    I'm also using it on a board to be etched by 14-year-old students.
    They're a lot worse than I am. For them I need at least 24 thou restring.
    Because of the way Eagle works, I can use the same library for all three
    projects, and just change the DRC settings.
    HTH,
    Rob
    come as I play?
    least 20 thou here.
    HTH,
    Rob
    come as I play?
    least 20 thou here.
    HTH,
    Rob
    mprowe@peritonlane.net over 10 years ago in reply to autodeskguest
    Ahhhhh.... Now, I see!! Or at least I think I do?
    come as I play?
    Thank you all, particularly Warren for the link to the FAQs.
    Regards, Martin
