EAGLE User Support (English) Library Pad Grows when p laced on Board?
  • Replies 30 replies
  • Subscribers 189 subscribers
  • Views 1724 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
I have a home-brew device (a couple of slots). In the device manager it
looks like this:
Note that the solder mask along the wire is the same size as the pad
diameter (red & green arrows).
However, when imported into a board, the pads on the large slot change
size?
See red arrow. Both slots are constructed the same way
(2xpadMillTopBottomtStop+bStop)
Why?
Can it be prevented?
Regards, Martin
  • mprowe@peritonlane.net
    mprowe@peritonlane.net over 10 years ago in reply to autodeskguest
    Ahhhhh.... Now, I see!! Or at least I think I do?
    Can't quite grasp the objective or reasoning behind it yet, but maybe it'll
    come as I play?
    Thank you all, particularly Warren for the link to the FAQs.
    Regards, Martin
    On 23/04/2016 1:45 a.m., Martin Rowe wrote:
    looks like this:
    size?
    Why?
    Regards, Martin
    Hi Martin
    Thanks for accessing the forum via EagleCentral
    Everyone is initially befuddled over pads that change their size between
    library and board editor.
    Check out the answer in the FAQ pages on the CadSoft site
    Specifically
    http://www.cadsoftusa.com/training-service/faq/#c92
    HTH
    Warren
    looks like this:
    size?
    Why?
    Regards, Martin
    Hi Martin
    Specifically
    HTH
    Warren
    autodeskguest over 10 years ago in reply to mprowe@peritonlane.net
    On 04/22/2016 01:56 PM, Martin Rowe wrote:
    Thank you Morton,
    Could you be a little more specific? What would I be looking for?
    Regards, Martin
    rest-ring
    Thank you Morton,
    Regards, Martin
    rest-ring
    Thank you Morton,
    Regards, Martin
    rest-ring
    Thank you Morton,
    Regards, Martin
    Thank you Morton,
    Regards, Martin
    Thank you Morton,
    Regards, Martin
    On 22.04.2016 15:45, Martin Rowe wrote:
    looks like this:
    size?
    Why?
    Regards, Martin
    Check your DRC settings.
