EAGLE User Support (English) Snap to Grid not working properly
  • Subscribers 189 subscribers
  • Views 3206 views
I have eight 0.1 uF capacitors (GRM43D package), which I would like in a nice neat row. i have the grid set to 0.05inch (size and Alt both set the same).   When i drag these components around on my PCB, they dont snap to quite the right place, and they end up in a slightly ragged line, with slightly different spacings, which looks horrible. The error is about 1/4 of the grid "size" setting.  If I look at the position coordinates with "properties" they are definitely in the wrong place, by a small amount.   !!!!!
    autodeskguest over 10 years ago in reply to e14 Contributor
    Am 23.05.2016 um 04:07 schrieb neil jepsen:
    Is there a good tutorial on how to modify an existing package in eagle,
    that is applicable to the menus in version 7.5 or later ?
    I'm trying to modify a a Maxim max202CWE because the two power supply
    pins on the device are
    1. Not shown on the symbol
    2. Are labelled as P.GND and P.Vcc, and I have no idea how to deal with
    these and get them connected. They seem to be eratic as to whether an
    air wire is generated or not.
    Actually i don't understand what "snap to grid" has to do with your
    problem getting the power pins connected.
    Invoke is your answer. You select invoke and then click your device or
    enter the name in the command line. A dialog will appear and you can
    select the power pins or whatever else.
    The reason for separate power is to avoid too many connections around an
    Op-Amp i. e. image
    Joern Paschedag
    Is there a good tutorial on how to modify an existing package in eagle, that is applicable to the menus in version 7.5 or later ?
    I'm trying to modify a a Maxim max202CWE because the two power supply pins on the device are
    2. Are labelled as P.GND and P.Vcc, and I have no idea how to deal with these and get them connected. They seem to be eratic as to whether an air wire is generated or not.
  • rachaelp
    rachaelp over 10 years ago in reply to e14 Contributor
    Hi Neil,
    I'm glad to hear your grid snap issues are resolved :-)
    For your latest issue, this may be harder to work out. My first question would be have you used the 'net' tool to connect things up or 'wire' tool? The correct one to use is 'net'.
    Best Regards,
    Rachael
    e14 Contributor over 10 years ago in reply to rachaelp
    Thankyou Rachael - once again. That indeed fixed the problem. I am following several tutorials obn Eagle, but none mention this problem,.
    I have  NEW PROBLEM - I have several components on my schematic that are clearly connected to  one other component , but no air wire is generated on the board screen. I have erassed & re-laid the schematic connection, and dragging the component on the schematic shows that it is connected. Putting a junction on the connection does the job, but why do I need a junction ?  If I delete the junction - the correct air wire remains in place ??
  • rachaelp
    Hi Neil,
    I suspect they were initially placed on different grids and whilst they all move correctly with respect to your new grid it's all relative to their original placements. What you need to do is align them back to your new grid. On windows/linux this is done by selecting the move command and then doing a ctrl + left mouse click on each component in turn. If you are on OSX it's the same except it's cmd + left mouse click.
    Best Regards,
    Rachael
