EAGLE User Support (English) re-touch:More than 16 layers
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 717 views
With the project I am working on, I'm starting to feel some pain about
the lack of more than 16 layers. I know I can most likely virtualize
some inner gnd-only layers (cloning the gerbers) but I'd like to ask
about the plans for this feature.
At the same time I know there are some challenges for the ones that work
with that many layers. First of all I'm thinking about polygon
processing speeds causing reluctance to do ratsnest until absolutely
necessary, but when doing power routing, it will need frequent fill
tests, but even doing ratsnest on a single net takes time. I wish this
function became more "live", so airwires would appeare instantly as you
place a via. My gut feeling as a programmer is that this is possbile to
speed up alot.
    On 09.05.2016 17:54, Jorge Garcia wrote:
    As you mention here, the users that require more than 16 layers
    generally use another tool. Getting them to switch to EAGLE even if it
    did support the appropriate design elements would not be a given. It
    goes back to figuring out a way to include these factors into the
    decisions for feature implementations.
    I'm going to think about this for a bit. If anyone has any ideas I'm all
    ears.
    I think you have the potential to grab new users simply by pricing.
    Afaik there is no tools that allows >16 layers even near Eagle's cost. I
    don't know (care) if KiCad can do this, but I definitely do not trust it
    when it comes to large designs. Of course I'm tempted to have a go at
    it, but now the time doesnt allow that. Even if I did look into
    alternate tools, it would have to be as open as eagle when it comes to
    data user-processing, wich eagle rules with the ULP.
    That last statement is a self-fulfilling prophecy.  Most people who think
    they will have boards that approach and may exceed 16 layers simply choose
    another CAD package.  They aren't going to even consider EAGLE since they
    can't be sure that it will be able to handle their full requirements.
    That's the wrong question to ask.  The question to ask is how much market
    share can we add by increasing the number of layers i.e. how many people
    would choose EAGLE IF it supported more layers.  But that question misses
    too.
    Hi James,
    You bring up a very valid point, however addressing it is difficult. How
    could we even gauge how much market share we could capture without it
    eventually turning into just a wild guess?
    I personally like the idea of the additional layers, I don't think the
    breaking of old scripts and ULPs is enough of a deterrent to the feature.
    I guess the key point here would be how we can further strengthen the
    argument for more layers in EAGLE. I'm not clear on how we could do
    that. I'm open to suggestions though image
      If you are routing 16+ layers then you most likely have many, many
    differential pairs and a bunch of length matching (like Morten's board
    above).
    The few boards that have come through my hands requiring more than
    sixteen layers have been due to a large number of GND and POWER plane
    layers for shielding. I agree that Morten's use case is probably more
    common.
      Until you have true, polished support for those design elements no
    one is going to choose EAGLE for those types of boards--the effort is
    simply too big when other tools do a lot to help.  So you have to address
    ALL of the design elements and then someone can consider EAGLE.  Until that
    happens you can't use stats from your current user base to see what support
    it would have because your current user base choose EAGLE in spite of it
    not supporting these requirements--so obviously they don't think it's
    important.
    ears.
    Best Regards,
    Jorge Garcia
    autodeskguest over 10 years ago in reply to autodeskguest
    CadSoft Support wrote on Wed, 04 May 2016 07:16
    Am 03.05.2016 um 12:27 schrieb Morten Leikvoll:
    On 02.05.2016 21:14, warrenbrayshaw wrote:
    On 3/05/2016 3:28 a.m., Richard Hammerl wrote:
    Am 29.04.2016 um 08:41 schrieb Morten Leikvoll:
    about
    virtualize
    ask
    that
    work
    absolutely
    fill
    this
    as you
    possbile to
    speed up alot.
    Currently we have no fixed plans for this. But we already put
    your
    request into our bugzilla system as a possible feature for V8.
    The discussion from Sept 2010 is well worth re-reading on this
    subject.
    Particularly James's words on the decision making process to
    purchase.
    http://www.eaglecentral.ca/index.php/mv/msg/38634/129058/736ed5d7e6ef3b087c
    ee2f741a79e2e5/#msg_129058
    Thanks for linking this old thread. I was the actual first one to
    respond to this thread[, apparently with a too complex solution].
    If Klaus worries are still the main worry, I have a much simpler
    solution that allows Cadsoft wants to keep the old structure, and
    addresses some concerns from the old thread.
    New projects on a new buture version could have an checkable
    "extended
    layer" mode in the stack setup. This feature will shift layers
    like
    Klaus suggested in the old thread. If this checkbox is not set,
    everything should work as before. When old projects are
    loaded/imported,
    this checkbox will ofcourse be cleared.
    For projects in "extended layer mode", all ULP's that work with
    extended
    layer modes would need a "#using extended_layermode" at the top.
    If an
    ULP without this key is run on a board in extended mode, an error
    like
    "This ULP is unsuitable for extended layer mode." should pop up.
    An old
    ULP would run as before on a non-extended layermode design.
    If you wonder why I need 16+, its because I'm working on a rather
    dense
    design with a 1500+ pin FPGA, more than 9 rather high current
    voltage
    rails (0.95V, 1.00V, 1.2v, 1.5v, 1.8v, 2.5v, 3.3v, 5v and 12v) ,
    256 bit
    (16x16) wide DDR4 memory at state of the art speed, 48 gigabit
    tranceivers (diff lanes of 8 gigabit), and you simply dont
    experiment
    with layer crossing with that kind of routing, especially not whe
    using
    Eagle where the simulation is not built in. (Yes I do have some
    ULP's to
    help me out here)
    I will probably manage to crowbar this in to 16 layers on this
    project,
    but the added comfort and time and blood saved in trial and error
    would
    be much valuable. Switching to a new tool is even more
    painful/time
    consuming. I would have to replace the man drawing it too.
    We will discuss this again for V8. There would be a lot of
    incompatabilities with the new additional signal layers. But we will
    check Klaus' and your ideas and see what will come out. We do not have
    too many customers that want to use more layers, but let's see if the
    pros justify the cons.
    Richard Hammerl
    too.  If you are routing 16+ layers then you most likely have many, many
    above).  Until you have true, polished support for those design elements no
    important.
    James.
    Order your EAGLE license from Stratford Digital at
    http://www.eaglelicenses.com
    work
    speed up alot.
    Currently we have no fixed plans for this. But we already put your
    The discussion from Sept 2010 is well worth re-reading on this subject.
    Particularly James's words on the decision making process to purchase.
    http://www.eaglecentral.ca/index.php/mv/msg/38634/129058/736ed5d7e6ef3b087cee2f741a79e2e5/#msg_129058
    New projects on a new buture version could have an checkable "extended
    layer" mode in the stack setup. This feature will shift layers like
    everything should work as before. When old projects are loaded/imported,
    For projects in "extended layer mode", all ULP's that work with extended
    layer modes would need a "#using extended_layermode" at the top. If an
    ULP without this key is run on a board in extended mode, an error like
    "This ULP is unsuitable for extended layer mode." should pop up. An old
    If you wonder why I need 16+, its because I'm working on a rather dense
    design with a 1500+ pin FPGA, more than 9 rather high current voltage
    rails (0.95V, 1.00V, 1.2v, 1.5v, 1.8v, 2.5v, 3.3v, 5v and 12v) , 256 bit
    tranceivers (diff lanes of 8 gigabit), and you simply dont experiment
    with layer crossing with that kind of routing, especially not whe using
    Eagle where the simulation is not built in. (Yes I do have some ULP's to
    help me out here)
    I will probably manage to crowbar this in to 16 layers on this project,
    but the added comfort and time and blood saved in trial and error would
    be much valuable. Switching to a new tool is even more painful/time
    Richard Hammerl
    speed up alot.
    help me out here)
    speed up alot.
    Warren
    speed up alot.
    Richard Hammerl
