EAGLE User Support (English) Routing Variants?
  • Views 1734 views
Routing Variants?
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
When I start a new design I get 22 entries in the Routing Variants dialog.
In time these reduce - sometimes to as low as four.
Why is this happening? I am not intentionally asking for fewer - even if I
knew how to!
Has the system "learnt" that many of the variants are not applicable and is
reducing the auto-route time for me?
Regards, Martin
Ver 7.6.0 Linux (64bit)
    Am 19.05.2016 um 12:25 schrieb Martin Rowe:
    Ah... Thank you Richard,
    That helped. In my case it was the "Preferred Directions" setting (* &
    Auto) that made the difference.
    So, lastly. What is the difference between "* None" (no preference?) and
    "Auto"?
    Regards, Martin
    None:  no preferred direction at all
    Auto:  The router chooses a preferred direction that is considered to
            be useful
    Richard Hammerl
  • mprowe@peritonlane.net
    "Auto"?
    Regards, Martin
    Am 18.05.2016 um 18:10 schrieb Martin Rowe:
    Hi Jorge,
    Thank you. However, is that the whole story? As the default, I have the
    effort set to "high" in all cases.
    In (just) two designs I have just checked, this is what I find.
    Case 1: Effort High - Variants 22. Effort Low - Variants 4
    Case 2: Effort High - Variants 4. Effort Low - Variants 3
    So, yes, some effect. But why does Case 2 only give 4 variants when the
    Effort is High?
    Regards, Martin
    How many layers do you route?
    Do you have set the "auto grid" option?
    Are there preferred directions set or is it also "auto"?
    Is the TopRouter variant active?
    All these is taken into consideration.
    Richard Hammerl
    Hi Jorge,
    Effort is High?
    Regards, Martin
    knew how to!
    Regards, Martin
    Hello Martin,
    The number of routing variants is dependent on the effort level set when
    you click on the autorouter dialog and the first dialog pops up. If
    Effort is set to high, then you'll get somewhere in the neighborhood of
    22 variants (sometimes more, sometimes less depending on the design). If
    Effort is set to low, then you'll usually get 3 or 4 variants.
    hth,
    Jorge Garcia
    Cadsoft Support
