EAGLE User Support (English) NAME command in ULP
  • Replies 16 replies
  • Subscribers 189 subscribers
  • Views 3038 views
NAME command in ULP
rachaelp
rachaelp over 10 years ago
I've using NAME within a ULP to automatically rename some busses/wires. It
works great when there is just one occurrence of a wire on a sheet but as
soon as there is a second I get a pop-up asking if I want to change just
the selected segment or all segments in the sheet. Looking at the docs I
can't see a way to make this happen automatically without prompting, does
anybody else know of a way to stop this prompt showing up?
If not then maybe the command needs an enhancement to allow the following
optional parameter for naming busses/wires:
NAME new_name (x y) T
where T = This segment, E = Every segment on sheet and A = All segments on
all sheets
Best Regards,
Rachael
    On 18/05/2016 9:01 p.m., Rachael wrote:
    rachaelp wrote on Wed, 18 May 2016 09:51
    So I just tried the SET CONFIRM option in my script and it does get rid
    of the nag, it would seem YES equates to the E option in my above example
    and I suspect NO would equate to the T (I haven't tried it) but sadly
    there is no way to make this work across all sheets with this option.
    It's also a sledge hammer approach to turn off all the warnings for the
    entire script with a blanket YES or NO auto confirmation. You could keep
    changing it in the script for every time you need to do something
    different, but I think my suggestion to be able to specify exactly how it
    should be handled for every occurrence of such commands within a script
    is much more powerful and much safer. In the docs it even gives a big
    warning about the dangers of using SET CONFIRM so it would seem sensible
    for CadSoft to enhance all such commands to provide a much more flexible,
    easier to use and safer option.
    I decided I really should test the NO option to make sure it does as I
    thought it did above and it would seem it does not. SET CONFIRM NO at the
    start of the script leaves me with my original naggy script. So I think
    it's likely a fluke that YES worked for the E option.... It gets me out of
    my current predicament but I actually need to be able to specify all three
    options at will to be able to finish my script as I would like.
    Hi
    There is a little more in place than you have mentioned.
    As the New name dialog only has an "OK" button and no "No" button, 'SET
    CONFIRM YES' and 'SET CONFIRM NO' both confirm the dialog. As the Help says.
    In your code you should place the CONFIRM instructions around the RENAME
    every time, as the help says
    SET CONFIRM YES
    RENAME
    SET CONFIRM OFF
    By default you would always  'Change Name of... this Segment' as that is
    what is preset.
    To rename the entire net by default use the following:
    set Cmd.Name.RenameEntireNetByDefault 1
    That will swap the default selection in the dialog to another radio
    button "all Segments on all Sheets"
    So the only one missing is the "Every Segment on this sheet" when the
    segments exist on other sheets as well. (Three radio buttons)
    "Every Segment on this sheet" can be the default option, when there are
    repeats of the net name on the current sheet and not on any other sheet.
    So the auto confirm can be applied to
    (1) this one Segment
    (2) all Segments  (this sheet and/or all sheets)
    HTH
    Waren
  • rachaelp
    Lorenz wrote on Wed, 18 May 2016 12:31
    if SET CONFIRM YES results in sccepting the default action in the
    dialog, then you should be able to use
    Cmd.Name.RenameEntireNetByDefault to at least select between "this
    segment only" and "all segments on all sheets"
    Not tested though
    Lorenz
    Hi Lorenz,
    Thanks for this, I will give this a go later and see if I can get things to
    work this way.
    Many thanks,
    Rachael
    Not tested though
    Lorenz
  • rachaelp
  • rachaelp
    Morten Leikvoll wrote on Wed, 18 May 2016 08:05
    On 15.05.2016 23:35, Rachael wrote:
    busses/wires. It
    but as
    change just
    docs I
    prompting, does
    following
    segments on
    all sheets
    I support this suggestion. In fact I flagged this issue many years
    ago.
    All the commands with the potential of resulting in a requester should
    have these options. Currently only the yes/no requesters can be
    pre-answered with the SET CONFIRM, but this doesnt work with other
    requesters.
    So I just tried the SET CONFIRM option in my script and it does get rid of
    the nag, it would seem YES equates to the E option in my above example and
    I suspect NO would equate to the T (I haven't tried it) but sadly there is
    should be handled for every occurrence of such commands within a script is
    much more powerful and much safer. In the docs it even gives a big warning
    about the dangers of using SET CONFIRM so it would seem sensible for
    all sheets
    I support this suggestion. In fact I flagged this issue many years ago.
    requesters.
