EAGLE User Support (English) Re: Move polygon
  • Subscribers 187 subscribers
  • Views 589 views
Re: Move polygon
Morten Leikvoll wrote:
I copy and rotate polygons now and then, and it is a bit hard to place it
correctly at the first click, so I miss a "move: polygon" function in the
context menu.
at least with eagle V6.6 you can select a whole polygon quite easyly.
Make sure you have an empty group (activate the group command and
select an empty reagion),
then ctrl-click (add to group) a segment of the polygon.
Lorenz
    context menu.
    After the 7.6.1 beta fix, I can, using an ULP, rightclick a polygon wire
    and select move polygon from the context menu.
    Imo, this feature deserves to become a standard feature in Eagle.
