EAGLE User Support (English) Net class specifications and name of some components
  • Replies 9 replies
  • Subscribers 189 subscribers
  • Views 1113 views
  • netclass
  • components.
Hello guys first of all i want to point that i dont have any experience about eagle and i am trying to design a pcb. It will be a commercial product so it needs to be perfect. I have finished my schematic design. There is no problem about that however i have some troubles in board part as you can guess. Firstly net class specifications i made, width 12mil,drill 20mil and clearance 12mil and i got 730 errors about them from drc checking. So what are wrongs with these numbers. What are the things i should be worry about when i am arranging them. In which case i should create more than one net class why ? Also   i want to make these holes in pcb. Because i just want to put 433 mhz rf module on it. So what should i put in the schematic to use them. These are not headers right ? Also i assumed that they are not just holes which you can make from board design or are they ? image
  • omega-5
    omega-5 over 10 years ago in reply to e14 Contributor
    Am 31.07.2016 um 16:26 schrieb Zeki Caner Adıyaman:
    I am using arduino nano and all these errors come from arduino part of the pcb
    https://www.element14.com/community/message/202705
    Which library do you use? Because there are libraries out there
    with errors in the layer assignment.
    Freundliche Grüße / Kind regards
    Friedrich
    ... benutzen Sie nntp://news.cadsoft.de und einen
    ... use NNTP://news.cadsoft.de and a
    functional news reader like Thunderbird!
  • omega-5
    Friedrich
    autodeskguest over 10 years ago in reply to e14 Contributor
    On 07/31/2016 11:54 AM, Zeki Caner Adıyaman wrote:
    What are the bad effects of decreasing clearance,width or drill ? For example i heard if there is high voltage on the wire clearance should be bigger . Is there any tip like that i must know
    https://www.element14.com/community/message/202796
    Most pcb houses do 8mil trace and clearance for no extra charge.
    At lower voltages the pcb manufacture you pick will set the limits. At
    higher voltages clearances depend on the regulatory rules in place where
    you are selling.
    The first few hits from duckduckgo.com
    http://www.smps.us/pcbtracespacing.html
    http://www.electronics-project-design.com/PCB-Design.html
    Paul
    you are selling.
    Paul
    e14 Contributor over 10 years ago in reply to autodeskguest
    Other threads had issues related to putting the layout and schematic of
    a plug in module into the PCB assembly. If you are mounting surface
    mount parts with fine pitch the part won't pass 12mil clearance and
    trace width.
    Paul
    You have to select each one to see what the issue is.
    Traces crossing traces (shorts) would give many errors.
    Just work on the list a little first.
    Paul R
    Paul R
