EAGLE User Support (English) Pin names not shown when   creating a device
  • Subscribers 187 subscribers
  • Views 258 views
unebonnevie
unebonnevie over 10 years ago
I am using EagleCAD 7.5.0.  I created a symbol and named all the pins.  I
also created package and named all the pads/pins corresponding to the pins
in the symbol.  When I attempt to create a device, only the names of pads
are shown and not shown in the pin column.  Because of that, I can't
connect the pins.
Please advise.
Thanks!
    connect the pins.
    Please advise.
    First guess: HELP CONNECT
    Also note that PAD names and PIN names have nothing in common -
    Normally, the PADs are just numbered according to the standard of the
    package, while the PIN names reflect their meaning/function.
    You might have a look at existing libraries for examples.
    Tilmann
