EAGLE User Support (English) eagle custom libraries disappeared
  • Replies 9 replies
  • Subscribers 191 subscribers
  • Views 2193 views
schrikdraad
schrikdraad over 10 years ago
Hello everybody,
I am using Eagle 7.6 and I am facing a problem I haven't seen before.
I have a set of custom libraries I created over the past years, which I store in a folder different than the standard Eagle Lib folder.
This has always worked well, but for some reason Eagle can't find them anymore
The situation:
- My custom libraries show up if I want to open a library in the control panel via File -> open -> library (see attachment 1)
- Only 1 library (connectors.lbr) shows up if I look in the library folder in the control panel  (see attachment 2)
- Only 1 library (connectors.lbr) shows up when I use the ADD function in the schematic editor.
If I go to Options -> directories, I can see that Eagle is pointing to my custom folder containing all my libraries.
Can somebody tell me why all the other libraries have disappeared? And...is there a way to solve this?
I hope to get a solution soon..
Thanks in advance
  • rachaelp
    rachaelp over 10 years ago in reply to schrikdraad
    Hi Rene,
    You might not be aware but there is another mirror of this forum and you've had a load of replies over there too. Element14's link with the mirror is currently broken so their replies aren't getting populated back here.
    Check out here for the other peoples suggestions: EAGLE Central Forums: eagle.support.eng » eagle custom libraries disappeared
    Best Regards,
    Rachael
  • dukepro
    dukepro over 10 years ago in reply to schrikdraad
    How about the Library search path?  Recall that on Windows, path
    elements need to be separated with a semicolon.
    From the Eagle Control Panel, try Options->Directories and check the
    Libraries value.
    HTH,
        - Chuck
    On 08/19/2016 08:15 AM, Rene Wassenburg wrote:
    Hi Michel,
    I only use schematic and board, no projects files.
    In any case that wouldn't matter as I can not even see my libraries in the control panel (except for 1).
    https://www.element14.com/community/message/203965
  • dukepro
    Libraries value.
    HTH,
        - Chuck
    Hi Michel,
  • dukepro
    Libraries value.
    HTH,
        - Chuck
    Hi Michel,
  • schrikdraad
    schrikdraad over 10 years ago in reply to michel_c12
    Hi Michel,
  • michel_c12
    michel_c12 over 10 years ago
    Do you use project file (eagle.epf) for your schematic and layout?
    If so, check if all libraries are still referenced inside this project file...
    Hope this can help you
    Michel
    I don't know, but if I were a betting man I'd lay odds it's something to
    do with Windows and the fact your directory falls under
    Libraries->Documents (or "My Documents" or C:\users\rene\Documents)
    As an experiment, use Windows explorer to copy that whole folder into,
    say, c:\working\eagle and point Eagle there. If I'm right, that being
    "just another folder" instead of a Special Magic Windows Thing should
    fix it.
    fix it.
    fix it.
