EAGLE User Support (English) Consistency errors
  • Replies 48 replies
  • Subscribers 183 subscribers
  • Views 5692 views
Consistency errors
maciv4
maciv4 over 9 years ago
Well, its happened again. I have consistency errors. How do I resolve them. I have tried to delete the offending part from the schematic, both with the board open and closed. I have tried replacing the offending part with a new part from a brand new library. I have tried to delete the part from the schematic, close the schematic reopen the schematic and the board. I have airwires on the board but can't place or select the part. What do I try next?
    autodeskguest over 9 years ago in reply to maciv4 +1
    On 01.09.2016 22:15, Jim McAuley wrote: First, I have downloaded a DRC file from a board house, and that is what I'm using to check the parts. Second, how would I know if this file is changing the pads…
  • maciv4
    maciv4 over 9 years ago in reply to autodeskguest
    I couldn't rename the part since I couldn't select the part.
  • maciv4
    maciv4 over 9 years ago in reply to maciv4
    I have since deleted the board, since it is faster to rebuild that to correct. I still have the original problem. The part that kept giving me errors that I could correct, is still wrong and noone knows why.
  • rachaelp
    rachaelp over 9 years ago in reply to maciv4
    Deleting the board was totally the wrong thing to do. I suspect most of us who have commented on this could have fixed your issues in a matter of minutes if we had access to the sch/brd and the lbr containing your problematic part. The problem is either we are not getting the full story or you aren't doing exactly as people have suggested.
    If you still have the original files and didn't just delete your only copy I suggest you either post them up so people can have a look or send the to Jorge Garcia at cadsoft (support@cadsoftusa.com).
    Best Regards,
    Rachael
  • rachaelp
    So knowing you couldn't select the part was a key bit of information. In what way is it not selecting? Is something else selecting first and you aren't then able to scroll through to the part you want to select for some reason?
  • maciv4
    maciv4 over 9 years ago in reply to rachaelp
    The only thing I could do was to type in "delete E$1", or "Move E$1". No buttons or other commands that I tried had any effect. I have since deleted the board. It was faster to rebuild (1week) than to continue to flail away at something noone knows how to fix. I am now continueing to try to solve the underlying problem with my libraries. Those errors were what caused all the problems in the first place.
  • rachaelp
    Like I said, that was key information which we could likely have used to help you solve your issues. It's not that nobody knows how to fix the problem, I'm sure that those of us who have commented on here to try and help you could fix your issue in a matter of minutes. Nothing in the errors you've given seemed particularly strange, the latest information about not being able to select the part would likely have lead to suggestions that may have solved your problem.
    If you have a backup of your files before you deleted your board then just send them to Jorge or post them up. You've spent a week on something that should have taken minutes to fix and now deleted it out of frustration. I can understand you are frustrated but deleting it wasn't very sensible. You could just have renamed it and then it wouldn't have been associated with the schematic anymore by name and you could have created a new board that way. But again, that would have been unnecessary too as the consistency errors are all solvable and you only had 3.
    Best Regards,
    Rachael
  • maciv4
    I didn't spend a week working on this problem, it was over a month.
    There weren't 3 errors. There were 3 consistency errors, and 19 errors, from 4 pins, on two identical parts, that I was trying to correct that caused the consistency errors.
    The last time I had this consistency errors I did send the file to Jorge, who corrected the problems but didn't tell me how. So nothing was learned there.
    I am still having problems with those parts.
    I have not stopped trying to solve this problem with these parts.
    I have edited the library over 8 time just today trying to resolve the problems.
    I have created a new board with just the parts on them to try to solve the problems.
    The errors are clearence errors. The part number is NQR010A. If you look up the datasheet maybe you can tell me why I keep getting these errors.
    Do you have any solutions?
    shabaz over 9 years ago in reply to maciv4
    Hi Jim,
    It is discussed here:
    Clearing errors
  • rachaelp
    This thread, from the title, is about consistency errors of which there are three. The week I was quoting was from your own post a few before mine.
    Yes, so the consistency errors aside, we need to work out why are you getting DRC errors then. The part itself is a simple 5-pin through hole with a 1.7mm pitch. It gives you a recommended pad layout which I assume you have followed. Does it appear the same in the board as your library specification? If not then it could be a DRC setting (restring maybe?) that is increasing your pad size on your through hole pads and causing the DRC errors.
    The next thing to ask (or possibly the first thing I should have asked!) is have you loaded an appropriate DRC file? I usually use one of the ones supplied by the board manufacturer I am using as a starting point and make alterations form there if I need to do so.
    Finally, are the DRC errors real issue you need to worry about or are they things you will just need to approve to clear the DRC error?
    Best Regards,
    Rachael
  • maciv4
    First, I have downloaded a DRC file from a board house, and that is what I'm using to check the parts. Second, how would I know if this file is changing the pads? I tried measuring the pad diameter by first changing the grid to a smaller increment and then recording the start diameter and the end diameter using the cursor.
    Thirdly, I have no idea if the errors can be ignored. They are between the pins of the component so I assume that they are important. I was getting overlap errors on the pins, those I felt I could ignore.
