EAGLE User Support (English) Consistency errors
  • Replies 48 replies
  • Subscribers 183 subscribers
  • Views 5693 views
Consistency errors
maciv4
maciv4 over 9 years ago
Well, its happened again. I have consistency errors. How do I resolve them. I have tried to delete the offending part from the schematic, both with the board open and closed. I have tried replacing the offending part with a new part from a brand new library. I have tried to delete the part from the schematic, close the schematic reopen the schematic and the board. I have airwires on the board but can't place or select the part. What do I try next?
    autodeskguest over 9 years ago in reply to maciv4 +1
    On 01.09.2016 22:15, Jim McAuley wrote: First, I have downloaded a DRC file from a board house, and that is what I'm using to check the parts. Second, how would I know if this file is changing the pads…
  • rachaelp
    rachaelp over 9 years ago in reply to maciv4
    Okay, that's one potential issue out of the way, that's fine.
    Jim McAuley wrote:
    Second, how would I know if this file is changing the pads? I tried measuring the pad diameter by first changing the grid to a smaller increment and then recording the start diameter and the end diameter using the cursor.
    I'd have the board and library part open side by side and zoomed in so the part fills the window. Then I would see if there was any obvious difference or start doing what you did with grids to try and determine any differences.
    Jim McAuley wrote:
    Thirdly, I have no idea if the errors can be ignored. They are between the pins of the component so I assume that they are important. I was getting overlap errors on the pins, those I felt I could ignore.
    Looking at the part, it's a 1.7mm pitch and the recommended pad diameter is 1.47mm nominal. That only leaves 0.23mm or 9 mil clearance before you even factor in tolerances so with a standard DRC file for a lot of online board houses that will probably give an error. That doesn't mean they can't do it though, these days most can easily, it might just add a little to the cost, but probably not if it's just one small part. Lots of components, especially fine pitch QFP / QFN parts will give DRC errors on a lot of standard DRC profiles and trying to increase clearances by reducing pad sizes to compensate may lead to solderability issues so you often have to make some compromises and either just approve these errors or start adjusting the DRC rules in order to be able to get a successful DRC pass.
    Is this a personal project or a commercial project? If its personal and you are hand soldering then you should be able to get it to work fine. If it's a commercial project and you need to think about long term manufacturing reliability then speak to your board house and get their opinion on it if you are concerned. Personally, if I were putting that on one of my boards I would probably just approve the DRC and make a note to investigate the soldering on my prototype boards to make sure there were no issues with shorts or incorrectly soldered joints.
    Best Regards,
    Rachael
  • maciv4
    maciv4 over 9 years ago in reply to rachaelp
    This is a commercial product, and the components will probably be hand soldered to start.
    I did check the library and the board component side by side as suggested, and found they are different. How do I get them to be the same? If I can do that on one board I can do that on any board. I am currently testing this out on a board that just has the two libraries alone, nothing else. Once I get that worked out I will try this on the finished product.
  • rachaelp
    Take a look here, this explains all about restring settings: EAGLE  -- What are the Restring Settings in the Design Rules for?
    autodeskguest over 9 years ago in reply to rachaelp
    https://www.element14.com/community/message/204876
    Hi Racheal
    While Jim is a E14 user, your 'here' shows nothing at Cadsoft Forum or
    EagelCentral.
    Warren
    Jim McAuley wrote on Thu, 01 September 2016 13:06
    The only thing I could do was to type in "delete E$1", or "Move E$1".
    No buttons or other commands that I tried had any effect.
    This smells like the appropriate origins layer wasn't displayed.
  • maciv4
    maciv4 over 9 years ago in reply to autodeskguest
    I never adjusted, touched, or changed the layers. This also happened three times.
    Am 01.09.2016 um 18:48 schrieb rachaelp:
    Jim McAuley wrote:
    I have since deleted the board, since it is faster to rebuild that to correct. I still have the original problem. The part that kept giving me errors that I could correct, is still wrong and noone knows why.
    Deleting the board was totally the wrong thing to do. I suspect most of us who have commented on this could have fixed your issues in a matter of minutes if we had access to the sch/brd and the lbr containing your problematic part. The problem is either we are not getting the full story or you aren't doing exactly as people have suggested.
    If you still have the original files and didn't just delete your only copy I suggest you either post them up so people can have a look or send the to Jorge Garcia at cadsoft (support@cadsoftusa.com (mailto:support@cadsoftusa.com)).
    Best Regards,
    Rachael
    https://www.element14.com/community/message/204891
    Hi Rachael,
    I think that deleting the board is sometimes the fastest way to rebuild
    it correctly,
    especially if someone says he doesn't know how to delete a board.
    Look at this thread and the help you and others have  provided,
    long  discussions which lead to nothing.
    I have the impression that the poster did not do what you suggested so
    no positive result.
    The poster should have placed the files here and I bet the users here
    would have helped immediately.
    Joern Paschedag
  • rachaelp
    rachaelp over 9 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Thu, 01 September 2016 23:44
    Hi Racheal
    EagelCentral.
    Warren
    Hi Warren, foiled by E14's flakey link with the other forums  again! It's
    there on E14 so they must have something weird in the system that copies it
    elsewhere that strips out the link....
    Anyway, here it is again for completeness on here:
    https://www.element14.com/community/community/experts/blog/2012/03/02/eagle--what-are-the-restring-settings-in-the-design-rules-for
    Best Regards,
    Rachael
  • rachaelp
    Well I would check that tOrigins and bOrigins are both turned on anyway just to be absolutely sure as per Olin's suggestion.
    Alternatively is something else selecting instead of the part you are trying to select? If so you can right click and select "Next" to scroll through the items which fall within the selection area until you get to the right one.
    First, I have downloaded a DRC file from a board house, and that is what I'm using to check the parts. Second, how would I know if this file is changing the pads? I tried measuring the pad diameter by first changing the grid to a smaller increment and then recording the start diameter and the end diameter using the cursor.
    This thread is frustrating reading. If you like, you can email the files
    (including customized libs) to me and I will offer free service to
    repair them under non-disclosure agreement. My email is provided below
    slightly scrambled to protect from dumb spam bots.
    yahoo.no, add mleikvol and @ before.
