EAGLE User Support (English) Trouble copying part to l ibrary
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 792 views
I'm running Eagle 4.16r2 (am I the last one?).  I created a part and
mistakenly saved it to a new library.  I'd like to move or copy it to
another one.  I open the destination library then right-click on the part
to be copied and select Copy to Library from the popup menu.  The part
appears in the board window for the destination library, but when I try to
save the part I get an error, "Can't create backup copy of file [path and
name of the destination library]."  When I click OK I get a warning, "Can't
remove old version of ."  What am
I doing wrong?
I should also point out that while Eagle lists the new library (and part)
in the Library listing of the Control Panel, and I can add the part to a
schematic, the library doesn't appear on disk with the rest of the Eagle
libraries.  You can see http://i.imgur.com/mLUpFGr.jpg that Eagle is
looking in the right place for the library (flip digits.lbr), but it's not
showing up (it should be between fifo.lbr and fox-electronics.libr).
Thanks for your help.
    autodeskguest over 10 years ago in reply to autodeskguest
    Try to start eagle as administrator
    That did it.  Thanks!
    Am 06.09.2016 um 20:30 schrieb Karl Lautman:
    Do you have full access to the directories you use for all eagle
    files?
    Yes.  I'm the Admin and only user of the machine Eagle is installed on.
    Even so. Imo after win xp all newer wins separate the users with their
    bloody rights management image
    Try to start eagle as administrator (right click the icon and choose
    "run as administrator" or something like that [I have "Als Administrator
    ausführen" on win81/64]
    Joern Paschedag
    files?
    Am 06.09.2016 um 18:37 schrieb Karl Lautman:
    Thanks for the suggestions, Joern and Rob.  The library with the new part
    shows up in Eagle but not in Windows Explorer (I'm running Win7 x64 Pro),
    so "use all" doesn't apply.  I exported it as a script and ran it within
    the destination library to produce the part, but got the same error as
    before when I tried to save it.  In fact, I recreated the part from scratch
    within the destination library (as I should have originally) and got the
    error when trying to save, so it looks like a problem with the destination
    library, which is write-enabled for all users.
    This library contains all the parts I create myself so it's easy to back up
    everything I create.  I had to reinstall Eagle after a system crash several
    months ago and just copied the backed up library into the lib directory, so
    maybe that's part of the issue.  I can access it from within Eagle and add
    parts from it to a schematic, though, so it's not totally ruined.  I should
    point out that the library with the new part (not the destination library)
    appears with a lock icon on its name in the library list in the Use library
    dialog, but this doesn't stop me from using the part in it.
    Any other tips?
    Then it seems that Bob is right and it is a problem of the windows
    rights management.
    Do you have full access to the directories you use for all eagle files?
    Joern Paschedag
    Any other tips?
    No, I still have a machine with that version.
    I doing wrong?
    Your destination library is probably write protected. You need to tell
    us what OS you're on, and where the library is stored, because your
    other symptoms sound like Windows 7/8/10 peculiarities.
    Am 06.09.2016 um 04:20 schrieb Karl Lautman:
    I doing wrong?
    Some times new libraries do not appear in alphabetical order, so check
    ALL names.
    Do a "use *" (use all) and check if the library is accessible now.
    If you have access to the new library you can also export it as script
    to a destination eagle has access to.
    Open your destination library and import the script.
    Some of this should work.
    Joern Paschedag
