EAGLE User Support (English) Ratsnest doing weird things
  • Subscribers 187 subscribers
  • Views 393 views
This happened many versions ago. I have been thinking of posting this
for a long time, but always ended up doing a manual ratsnest for the
wire as the quick resort. Finally here is some doc pics.
When routing a path from a track where there is no airwire (ctrl-click
on a wire/via/pad) Eagle ends up displaying a double airwire. See
attached img (double-airwire). Routing the blue track, starting at the
via toward C1 and stopping midway leaves the two same-net airwires. I
would like to see eagle clean up the airwire when route is finished, or
even at the first click.
Also, this can end up removing an airwire. See 2nd img. Start routing at
G2, shift-clicking between G2&H3 and stop (esc) there. The airwire to G1
is lost, but you can see it is the same net.
Can you please fix this?
    autodeskguest over 10 years ago in reply to autodeskguest
    Hello Morten,
    I hope you're doing well. The devs are asking for sample files
    illustrating the issue for analysis and correction.
    If you can, e-mail the files to support@cadsoftusa.com.
    Best Regards,
    Jorge Garcia
    Mail sent, let me know if you don't find it image
    Hello Morten,
    Best Regards,
    Jorge Garcia
    Hi Morten,
    Sorry I took so long to get back to you. Thank you for the images, I
    have created and submitted a bug report on both these issue.
    The second issue to me is particularly frightening since that could
    cause a board to fail if you are missing connections.
    Best Regards,
    Jorge Garcia
