EAGLE User Support (English) Changing normal vias to b lind or burred vias
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 2204 views
I'm developing my first 4-layer board in v4.16.  My plan is to prototype it
with Osh Park before doing a pilot run with the final vendor.  For
aesthetic reasons (this is for a piece of functional sculpture), I'd like
the final version to use blind and, possibly, buried vias (so one side of
the PCB will be "unblemished"), but Osh only supports normal ones that go
all the way through.  It's not clear to me from the Eagle docs
1.  How to specify which type of via is created when routing on an internal
layer, or
2.  How to change a normal via to a blind or buried one later.
Any tips on either or both of these issues appreciated.  I'm wondering how
big a chore it's going to be to go back and change all the normal vias for
the production version.
Thanks.
    autodeskguest over 10 years ago in reply to autodeskguest
    Rene:
    Got it.  Had my Setup wrong on Layers.  Thanks.
    Am 23.09.2016 um 19:21 schrieb Karl Lautman:
    If blind, how do I make it regular, and vice-versa?  As far as I can tell,
    CHANGE VIA, if I'm not misunderstanding you.
    Rene
    On 24/09/2016 8:28 a.m., Karl Lautman wrote:
    On second thought, I don't think that will work, Warren.  There actually
    ARE some vias (pads, actually) that I need to go all the way through, it's
    just that they'll be covered by some components (display modules) that
    connect to them on the "unblemished" side so you won't see them.  This side
    has these modules and nothing else.  Forgot about that.
    As always
    You will only receive applicable suggestions if the OP takes the time to
    provides accurate descriptions in the first instance.
    Good Luck
    Warren
    Warren:  That's a good idea.  I'll ask the board house if they can do that,
    though I'd still like to know how to control blind/buried/regular vias.
    Karl
    layer, or
    Thanks.
    Hi
    You may not need to do much with the design.
    Your prototype is a two sided core. If the board house attaches another
    core to it with pre-preg, hey presto, you have what you need. In this
    stack-up you are using layers 1 and 2 and nothing on 15 and 16.
    So you only need to change all vias to a depth of 1-2
    HTH
    Warren
    Lorenz:  If I start routing a trace on the top layer and then center-click
    to move it to the 2nd layer, will that via be a blind via or regular via?
    changing layers only works on traces; corresponding vias get changed
    automatically, but you can't change them directly.
    Morten:  I want to end up with one side containing only solder mask:  no
    holes (filled or otherwise) or even traces beneath the mask.  The other
    side of the board will contain all the circuitry in surface mount packages,
    connected via traces on this side and the two inner layers (both of which
    will be signal layers).
    1.  What do 6 layers get me that I can't get with 4?
    2.  These would still be visible where they penetrated the mask.
    3.  Won't this cause the mask to cover everything, including pads I need to
    solder to?
    4.  Same problem as 2.
    layer, or
    Blind vias are vias you dont see, cause they are internal only, in your
    case between layer 2 and 3. They normally need microvias between L1-2
    and in your case, maybe between L3-4 too.
    I'm not sure if I understand you, but if you want it to be "free of
    holes", there are easier and cheaper ways than using blind vias.
    1-If there is nothing on the board but hole mounted components, you can
    just add two outer layers of nothing. A 6 layer board may be cheaper
    than what you are trying to do. You will also get some artistic freedom
    to draw art on the outer layers image
    2-Just fill the vias with solder.
    3-Stop filled holes, make the diameter as small as possible, and
    under DRC->Masks, set the "Limit" parameter larger than your via drill
    parameter to make eagle remove stop mask over them. Also talk to your
    manufacturer to make sure they can fill them. The end result will not be
    as flat as when using 2 or blind+microvias, but sufficient to keep
    dirt/humidity out.
    4-Copper filled vias. You need to find a manufacturer that can do that
    and actually talk to them about it. If your design has PAD's, you need
    to make your own CAM file to output VIAs in a separate file, so they
    don't fill your PADs too.
    layer, or
    first you need to configure the stackup in tools/DRC/Layers
    than you can use "change layer" or the info dialog to modify the vias
    after the fact, and the middle mouse contect menu during routing.
    Lorenz
