EAGLE User Support (English) Polygon problem/bug.
  • Replies 14 replies
  • Views 1726 views
Joop14
Joop14 over 10 years ago
Dear Cadsoft team,
I created two polygons on the same layer. One covers the whole board and
has rank 1 and has thermals switched off.
The other polygon is smaller and has rank 2 and has thermals switched on.
The problem/bug is that the thermals on/off property is not taken into
account when checking the ranking of the two polygons. The thermals are
always switched off.
Could you fix this please?
Thanks.
    autodeskguest over 10 years ago in reply to Joop14
    On 7/10/2016 10:34 p.m., Joop wrote:
    Thanks Warren.
    It works when I do it exactly the same way as you describe.
    The thing is, apart from a couple of connectors, all components are smd.
    So, I prefer to have the outer polygon which usually covers the whole
    board,
    set to thermals off. Then I want to draw two or three small polygons that
    cover
    only some throughole connectors with thermals set to on.
    This is the opposite of what you proposed and I can't get it to work.
    Hi
    There is a way to do it. See the attached
    The board sized outer GND polygon is made Rank 3, Thermals 'Off'.
    That makes the whole board, Thermals off and satisfies your SMDs.
    Next you thwart its efforts in the region of you connector with a
    polygon at Rank 2 with an Eagle generated signal name like S$7.
    Rank 2 is a higher ranking than the big polygon so the big polygon
    cannot go into that area. Hence there's a hole in the big polygon in the
    region of your connector.
    The you make another polygon a little larger than the last and give it
    Signal = GND,  Rank 1 , Thermals 'On'.
    Having a higher rank it wins and  suppresses the rank 2 polygon
    underneath it so the Rank 2 polygon becomes irrelevant but it's still
    doing its job holding the big rank 3 polygon at bay.
    With the RAnk1 polygon having  Thermals 'On', the connector pads have
    thermals as desired.
    Now there is an issue to be understood.
    Do a ratsnest and look in the spaces beside the traces. There's
    something there. It's the drawn outline of the unfilled Rank 2 polygon.
    This is a visual effect only in the CAD display.
    When you create your Gerber files, it is not there because the drawn
    polygon outline is not part of a Gerber. It is the calculated signal
    polygon that is conveyed to the Gerber.
    View the gerber to confirm this for yourself.
    I suspect, any print output from Eagle used to home-bake a board may
    show these display artefacts.  I did not check this.
    I understand many create the gerber and print that for their toner
    transfer or photo process.
    HTH
    Warren
    poly_test_v6-6_3.zip
  • Joop14
    Thanks Warren.
    board,
    cover
    On 7/10/2016 7:32 p.m., Joop wrote:
    I was mistaken. I am using V6.6, the last V6 version.
    Thanks anyway. I'll let you how it ends with the polygon test & V7.
    I tried it in v6.6 and it works fine there
    See attached board.
    One SMD and three pads are all connected to the same net as the two
    polygons. Turn off "Settings > Misc > Ratsnest processes polygons" to
    see the airwires.
    The polygons have the same name as the signal connected to those contacts.
    The outer Polygon is Rank 1 with thermals on
    THe inner is rank 2 with thermals off
    HTH
    Warren
    Joop wrote:
    warrenbrayshaw wrote on Thu, 06 October 2016 20:07
    Well, working the way it does, gives me exactly what you described you
    needed. No thermals on SMD and thermals on pads. At least it works for
    me when I tried it using v7.2.2, before I wrote the reply.
    How about you make a small board to illustrate your problem and post it
    here with an image of what you see.
    Will do that. First I'll try with V7.7.
    It could be that this is a bug that has already been solved some time ago.
    I still use V6.22. We have the license for V7 but it's unusable slow with
    complex boards on our hardware.
    no need to reinvent the wheel 8-)
    just look at the example board file I posted earlier in this thread.
    thermals off is not overridden by thermal on, whereas thermal off over
    thermal on works as expected.
    Lorenz
  • Joop14
    Joop14 over 10 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Fri, 07 October 2016 03:46
    You could tweak your v6.2 to version 6.6 here
    ftp://ftp.cadsoft.de/eagle/program/6.6/
    The release notes show quite a bit fixed before v6 ended. You may as
    well have it.
    HTH
    Warren
    The release notes show quite a bit fixed before v6 ended. You may as well
    have it.
    HTH
    Warren
  • Joop14
    Warren
    Thanks for helping.
    On 6/10/2016 10:56 p.m., Joop wrote:
    warrenbrayshaw wrote on Thu, 06 October 2016 11:19
    The manual says the following
    <quote>... A polygon with rank = 1 has the highest priority in the
    Layout Editor, no other polygon drawn in the layout is ever subtracted
    from it, while one with rank = 6 has the lowest priority. As soon as
    there is an overlap with a higher rank, the appropriate area is cut out
    from the polygon with rank = 6.
    Polygons with the same rank are compared by the DRC. The rank property
    works only for polygons with different signals. For overlapping
    polygons
    with the same signal name it is without effect. They will be drawn one
    over the other....<end quote>
    Why not honoring the rank with same nets? This is the problem that needs to
    be fixed.
    So for a board needing pads with thermals and SMD without:
    Leave the library thermals on for the PADS and SMD
    Create an outer polygon with thermals on and Rank =1
    Create the complex inner polygon that covers only the SMD with with
    thermals off and Rank = 2
    I tried that, it doesn't work for the above reason.
    Thanks for trying to help anyway.
    Warren
  • Joop14
    polygons
    be fixed.
    On 5/10/2016 9:45 p.m., Joop wrote:
    Dear Cadsoft team,
    Thanks.
    As I see it there is nothing to fix.
    Rank 1 is the highest ranked. Think of it as place getters in a race.
    1st is the highest ranked 2nd is a lower performer. 3rd...and so on.
    The thermal flag for a polygon simply indicates the polygon should
    honour the thermal setting of the library package. The polygon can never
    make a thermal that has not already been set for a pad in the library.
    All it can do is deny you a previously set thermal, in the library, when
    you set thermals off for the polygon.
    HTH
    Warren
