EAGLE User Support (English) How designing silkscreen a PCB for RF applications
  • Views 453 views
Hi, I'm using Eagle and designing a PCB for RF applications and need to
create a shield or border with gold bath in which some RF components are
placed, but I nedd that is free of the mask silkscreen, as you can see in
the picture, someone could tell me how I can do in Eagle?
  • rachaelp
    rachaelp over 10 years ago
    wsalas wrote on Fri, 07 October 2016 00:59
    I assume you mean you need it to be free of the solder mask (silkscreen is
    the legends with component references printed on it) which is fairly
    straightforward to achieve.
    1) Select the WIRE tool.
    2) Change layer to tStop (or bStop for the bottom side)
    3) Select a trace width to match your shield width.
    4) Draw over the top of the shield trace.
    Best Regards,
    Rachael
