EAGLE User Support (English) explicit net names in schematics issue
  • Subscribers 187 subscribers
  • Views 444 views
For components having pin direction "pwr" there is an explicit
netname/signal generated taking the pin name. (this post does not cover
the long discussed controversy of that feature).
I found issues when trying to write a script to find where a selected
airwire in the board is drawn on the schematic (yes I have large
designs). The board do make airwires of these explicit names, but their
visibility seems to be limited in schematics.
First, I discovered that the UL_SCHEMATIC "nets" loop member did not
cover these nets. But, for some reason, the allnets loop member does. I
am not sure why, but it did give me a reminder to use allnets instead of
nets in my script.
Then I discovered that the schematic show command does not find these
explicit names unless there is a wire drawn to one of the pins. But the
board show does.
Try adding any component with a VCC pwr pin, for example a 74xx chip,
and do "show vcc" from both board and schematic. Only board perspective
will show it.
I'd suggest this was a bug.
    autodeskguest over 10 years ago in reply to autodeskguest
    nets in my script.
    board show does.
    will show it.
    Hi Morten,
    This isn't a bug, but I would be hard pressed to call it "intuitive". I
    personally have never been a fan of pwr pin name defining a net feature.
    I've always felt it's ambiguous and error-prone but I'm sure there are
    users who like it that way for their own reasons.
    If I were to venture a guess, the nets loop member probably only grabs
    explicitly drawn net segments. Since the pwr pins are implicit(no nets
    by default) it probably doesn't include them. Allnets would be the way
    to go on this one.
    The solution to this would be a change of behaviour and that would be a
    hard sell to the devs and the EAGLE users who are used to it working
    that way.
    hth,
    Jorge Garcia
    Your first paragraph sounds like an invitation to pick up that old
    thread again. Although I have suggested in those old posts how eagle
    could change and still keep backward compatibility and/or improve DRC,
    this is subject for a different thread.
    The change of behaviour I do not agree on. The only thing I basically
    ask is for is that "show " shows the open pins with
    explicit nets at shcematic.
    For multi sheet hits where eagle is popping up a list dialog, The pins
    not belonging to a segment should show in the list too.
    Not showing it is wrong, cause the net is there even if you dont see a
    segment/wire.
    nets in my script.
    board show does.
    will show it.
    Hi Morten,
    to go on this one.
    that way.
    hth,
    Jorge Garcia
