EAGLE User Support (English) ULP problems - UL_PIN object's "net" attribute
  • Subscribers 187 subscribers
  • Views 578 views
Hi all,
According to the help for the UL_PIN object,
The net data member returns the name of the net to which this pin is
connected (only available in a schematic context).
So, as I understand it, something like:
         S.parts(P) {
            if(P.name==find) {
               P.device.gates(G)
                  G.symbol.pins(PIN)
                     printf("%s\t%s\n", PIN.name, PIN.net);
ought to print a list of the pin names of a given device, and the nets
they're connected to. However, it doesn't. It prints the names, but all
the nets are just blank. This is the same on V4.16, V5.12 and V7.6
What am I doing wrong?
Cheers,
Rob
    On 21/10/16 21:10, René König wrote:
    Hi Rob!
    You need to loop through a device's instances. For the entire schematic:
    schematic(SCH)
        SCH.sheets(S)
            S.instances(I)
                if(I.name == find)
                    I.gate.symbol.pins(PIN)
                        string s;
                        sprintf(s, "%s\t%s\n", PIN.name, PIN.net);
                        dlgMessageBox(s);
    No luck with that. I got a syntax error on S.instances(I) and when I
    tried an extra layer:
         S.parts(P)
            P.instances(I)
    then I got no output at all.
    Ah... hang on...
    OK, so the problem is the instance isn't named right.
             SCH.sheets(S)
                S.parts(P)
                   if(P.name==find)
                      P.instances(I)
    seems to work. Thanks, Rene.
    (It does feel like a bug that the simpler form doesn't work, though)
    Cheers,
    Rob
    Hi Rob!
    schematic(SCH)
        SCH.sheets(S)
            S.instances(I)
                if(I.name == find)
                        string s;
                        dlgMessageBox(s);
    Rene
